Hello
I recently faced an issue with Directory Opus where the context menu fails to appear for certain file types when I right-click. For example, while .txt and .jpg files display the expected menu options, file types like .zip and .docx do not show any context menu at all. This behavior started after I installed a recent update, but I'm not sure if it's directly related. ![]()
I've already tried resetting the context menu settings to default and even reinstalled Directory Opus, but the problem persists.
Checked Context menu missing entries Okta guide for reference .
Could this be related to file type associations or a conflict with other installed software?
Any guidance on troubleshooting or a fix would be appreciated!
Thank you ! ![]()
