Mass rename using "Regular Expressions and Find And Replace"
Hi forum and Dopus Support Team,
I have a few 100 files which all have a certain name portion at the end of the filename as follows:
[filename]~20200116-09-[minute-second].extension
I want to delete that ~20200116-09-[minute-second] part from the file name.
The part ~20200116-09- is always the same, and the part [minute-second] is different.
I suppose this works with "Regular Expressions and Find And Replace", using the "Rename" dialog:
What would I have to enter in the "Old Name" field to ensure that all name components are found and deleted according to the pattern ~20200116-09-[minute-second], regardless of the value of the [minute-second] part?
An asterisk or multiple question marks don't seem to work (please bear with my Regular Expression ignorance) :o
Many thanks for help!
You probably want just Regular Expressions (not the Find & Replace mode).
Old name: ^(.*)~20200116-09-.*
New name: \1
Thank you very much Jon!
I tried that -- could it be that the Old name should read slightly different:
^(.*)~20200116-09-*
Only this seems to catch all wanted files?
I don't think so, but if it works great :slight_smile:
Why would you (not) think so?
Sorry, am asking out of complete RegExp illiteracy -- but don't want to break something :grimacing:
(actually, your syntax ^(.*)~20200116-09-.* doesn't catch any of the files :frowning: )
Even this seems to completely work:
^(.*)~20200116-09
This also works:
^(.*)~20200116-09*.*
(all with "Ignore extension" checked)
:thinking: :question:
Since you didn't provide an actual example filename and just described the format I had to make up the test names to use, but it seems to work to me:
I'm sorry, my fault. I didn't describe the format exactly enough (actually, I described it incorrectly). Sorry.
The filenames actually look like this, for example:
blahblah~20200116-093959.zip
The part ~20200116-09 is always the same, and I would like to rename them to
blahblah.zip
Take out the second hyphen.
Yeah, that works:
^(.*)~20200116-09.*
Strangely (to me), these two seem to do exactly the same:
^(.*)~20200116-09.
^(.*)~20200116-09
Sorry, I'm aware that I'm just taking half an hour of time from a world-class software developer, with my dummie RegEx question.
Please tell me where I can donate. Solving this issue is just about to save my a** here :grimacing:
Bear with me -- I have another unexpected case where I have to rename some 1000 files having a similar filename pattern, where the datestamp has to be removed from the filenames.
The files look like this again:
Example:
BlahBlah~20200116-200937.zip
Pattern:
[Filename]~[yyyymmdd-HHMMSS].[extension]
The following simple regex seems to catch all files, and remove the complete part after and including the ~Tilde, while keeping the file extension:
Old name
New name
\1
Do you guys also think this regex could work like this?
Thanks heaps for comments!
If it doesn't work, try ^(.*)~.* for the old name.
Thanks very much!
Since I probably will need this method (deleting a suffix starting with a certain character string) in the file name) even more often in the future, would you (or some other reader) mind briefly explaining the syntax of ^(.*)~.* to me?
^ means anchor to the start of the string.
.* means match any number of characters. If it's in () it defines a capture group that can be used in the replacement string (e.g. \1 refers to the first capture group)
~ is a literal character that it's searching for.
So what it means is, starting from the start of the string, capture all characters up until the first ~ character.
Thank you Jon. I appreciate your explanation very much!
I think I will be able to work out from here how to capture any filename suffix starting with a certain string.
Suppose I want to delete the date suffix from this file pattern:
BlahBlah-(2019-11-[dd-HHMMSS]).zip
Then I'd use this ^(.*)-(2019-11-.* for the search string, right?
Last question :blush:: why is the .* needed (or, used here) at the end of the search Regex? Does this have something to do with the file extension?
The parenthesis needs to be escaped. The leading ^ is not needed in RegEx Mode. So you would use (.*)-\(2019-11-.*.
No, the option Ignore extension is checked. In RegEx Mode the string needs to represent the entire filename. That's the main difference to RegEx+F&R.
Have a look at the regex explanations in the Opus help. Although it claims to be just an introduction it is very comprehensive and covers a lot of ground. You'll get good mileage from it.
Whoa, thanks!
In this case, for the original task (remove filename date suffix starting with ~Tilde, like blahblah~20200116-093959.zip), already this syntax fully does it:
Old name
New name
\1
Correct? :open_mouth:
No. It doesn't get shorter than this:
2020-01-18 - 12.00.56 - Rename_-_Directory_Opus
Like in your question before and in my first posting. There I didn't remove the ^ because it's just a cosmetic thing and I didn't want to cause confusion.
Why don't you just try it out? It's free :wink:
Yeah I tried it, and this worked, on like blahblah~20200116-093959.zip:
Old name
New name
\1
:thinking::thinking::thinking:
