nested folder trees
Hey! Is there any way to do 2 nested folder trees? I.e. click on a folder and see its contents to the right, then click a second folder tree opens and you can drill down and to the far right see the files?
Do you mean this:
Column view lister request - Help & Support - Directory Opus Resource Centre (dopus.com)
Yes exactly! Thanks for the quick reply. I guess its called column view in one-commander.
Listary and QAP's popup menu function a bit like that, but you can't use the right mouse button. . .
