We are trialing a new installation method which hopefully means you do not need to reboot after installing an update (the installer will offer to quit and restart Opus instead). Please let us know if you encounter any problems with this.
Installing 12.12.1 on top of 12.12 required a Retry for the help files and a reboot.
Installing 12.12.1 on top of 12.12.1 went straight through, no reboot needed.
Directory Opus Pro 12.12.1 (Beta) Build 6982 x64
OS 6.1 (B:7601 P:2 T:1) SP 1.0 "Service Pack 1"
Installing 12.12.1 on top of 12.12 went 'butter smooth' ! It asked if I wanted to close DO for the install, then after it was finished installing, asked if I wanted to re-start DO. Went very smooth, and thank you for updating the installer so that no system restart is needed!
THANK YOU so much for this, i've been praying for this for the past decade!! every time i saw an update, i would have a warm and a dreadful feeling at the same time.. i have fifty million things open at the same time, restarts are costly!!
Those are turned off by default now, but can be turned on via Preferences / Miscellaneous / Advanced [Behavior]: display_release_history if you liked having them.
You can also add Help RELEASENOTES to the Help menu (also there in the new default menus, if you reset the toolbar to factory defaults) to quickly open the release notes for the current version.
When I did the reboot, I found there were Windows 10 updates waiting to be automatically applied. I wonder if they could have interefered with the DOpus update?
