Hi forum & GPsoft team
Lately (like for about a year) I've come to the impression that Dopus has started to become less stable than it used to be.
Unfortunately I have to say that there is only one of the about 250 applications that I use which actually crashes more often than Dopus (that app being Dragon NaturallySpeaking).
For example, Dopus very often completely locks when a html file or mht file is pre-viewed in the preview pane.
The other continued, major annoyance for me is that Dopus literally brings my computer to a standstill for like two minutes every time it is started, just because it thinks it must calculate every single of my 100,000 folders' size anew every time (or at least the size of the 500-something folders that are shown in my Dopus Startup Tab Group).
PLEASE GPSOFT, MAKE DOPUS CACHE or remember the folders' sizes in between sessions, like even the simple freeware "Folder Size for Windows Explorer" does. Or at least, don't have Dopus calculate the size of folders in tabs that are not active, at the same time it calculates the folders' size in the active tab. This regularly almost breaks my hard drives (audibly).
The same behaviour of Dopus is probably also the reason why Dopus can take as long as 20 seconds to simply delete a 10kb *.txt file or something -- after this, Dopus unnecessarily seems to be re-calculating every directories' size that is in the same lister.
Thanks already for (serious) consideration,
Regards David.P
