Hi
Is it possible that the favorites folder in Dopus, is the same as the ones in Windows Explorer?
Automatically of cause, I know that I kan add the same folders manually.
Regards Lars
Hi
Regards Lars
If you navigate to /favorites (older Windows) or /profile/Links (newer Windows, or Win7 at least) you can find the Explorer favorites there, to display them in a lister.
Start Menu button shows some examples of how you could make a menu which shows what's in that folder, to replace the favorites menu.
Hi
Thank you for that, it's definitely better than nothing
I have added the "Links" folder to favorites (I actually didn't knew that this was the meaning with the Links folder
Is there no way to make the Links folder expandable in the tree view?
/nOrphf
I don't think that's possible, sorry. The Links folder contains shortcuts, which are files as far as the folder tree is concerned.
Can I add it as a feature request?
Or should I start a new post somewhere?
Regards Lars
No need to do anything. Posting to the forum with a linked account is enough to make things a feature request.
