Probably bug in display column
Hi, when in the lister (list view mode) there are files with very long filenames (in different columns) there's a display bug (I attached a screenshot).
When this happens I must close and re-open the lister to reset.
I saw this bug dozen of times.
Is there a way to set maxsize of columns in list view mode (not in detail mode) to my requirements?
I'd like to view names truncated (with 3 dots at the end of names...).
Thank you
Hello Blisset,
I'm not quite certain what you mean.
Is the bug perhaps this:
[/u]
Let us know.
Regards,
Zippo
Hello Blisset,
I'm sorry,
I can't reproduce this result.
With extremely long filenames in list view,
I don't see a truncated display.
Can you tell us more?
Regards,
Zippo
Oh, I see it now.
Is it that you want to be able to specify a folder format so that list view has specific column widths?
I don't think this can be done now,
but as you can see from my prevoius posts referenced here,
these things are being thought about by GPSoft.
Let us know.
Regards,
Zippo
[quote="Zippo"]Hello Blisset,
[/u]
Let us know.
Regards,
Zippo[/quote]
Yes, it happens after autoscrolling with long file names (example 80 chars or more) and more easily it happens when there are a lot of files in the folder (3-4 columns) and 2 or more filenames have long file names.
Try to RENAME long filenames and then press F5, after autoscroll, the bug occurs.
The bug is surely related to autoscroll, it happens after an operation (file renaming for example), not simply scrolling the columns.
In List mode there are 2 filename view modes:
*truncated view (when I enter in a folder, long filenames are truncated with 3-dots)
*extended view (after press F5, names are displayed complete).
This bug happens in 2nd mode only, never in first mode.
Excuse me for bad english.
Hello Blisset,
I am using an old computer.
[quote]*truncated view (when I enter in a folder, long filenames are truncated with 3-dots)
[/quote]
My computer is too old.
I see both views.
Unfortunately I see this different than you do.
I'm sorry,
Can anyone reproduce the Bug Blisset has found?
It is similar to the bug Raisers found, but different.
Thankyou Blisset,
Your English was very good.
The Giro is a favorite of mine.
It is only very recently that I have been able to see this on television here in the United States.
The first time I saw the Giro, 22 year old Damiano Cunego was Champion !!!!
Kind Regards,
Zippo
[/quote]
I see both views.[/quote]
I see both views too.
First, when I enter in a folder I see namefiles truncated.
After, if I press F5, I see second view (extended namefiles).
I can verify the bug that Blisset is experiencing, because I am experiencing the same exact problem.
I just installed DO 8.2.2.5 and I am in love with the program (I plan on purchasing it soon), but this is a bit of an annoyance.
