Its no big deal i guess to just continue using winrar instead, or even just use the EXTRACT HERE command instead, then just drag and drop in the file to the destination lister window.
I just thought there might have been an option command I could add to the EXTRACT TO button commands.
Maybe i just need to stop being lazy and read up on it myself lol...
This post i think is also the same problem.. but looks like no solution
The correct command to extract a .rar or .zip archive from the Source Lister to the Destination Lister should be:
Copy Extract
You should only use the TO option when you are explicitly naming a specific different folder to copy or extract files to. In that case, the extracted objects go to the specified folder, not the folder that is listed in the Destination Lister.
[quote="andyg"]I am using the default command for Extract in FILE -> FILE COMMANDS
I dont know how to actually find the actual commands or switches as i assume its all internal[/quote]
I'm confused now. You were talking about "EXTRACT HERE" and "EXTRACT TO" in the first post. Can you clarify exactly what you're doing and which things work and don't work?
