My apologies if this has been covered, but I'm not having much luck finding it.
I want to rename and resort in to subdirectories a bunch of ebooks. So I have the "ebook author" visible in columns and select that during the rename process. Doesn't seem to work. Screens below.
Since you're moving things into a new folder, there should be a fourth Location column in the preview list. Is it there out of view in the screenshot, or scrolled off to the right?
