Can someone please tell me how I can rename multiple folders as in my example:
From -
[2008] MovieName1
[2008] MovieName2
To -
MovieName1 [2008]
MovieName2 [2008]
I would like to control the space after MovieName and the year. I have many folders with different movie names, what I am trying to accomplish is to just have the year after the name of the movies and not before.
I tried to figure this out but couldn't and would greatly appreciate any help!
Thanks for the reply, I looked and failed to figure out how to accomplish what I am looking to do. This has turned out to be way too advance for a simple task! Can someone guide me to do what I want? That's the only feature I would be using for time being.
Can I ask you maybe not so tricky question to you! This would be MIND BLOWING if it can be done. I have a huge collection of MP3s. Since recently I purchased an iPod I need to rename the album names in every single songs I have within every sub-folders.
For example:
MovieName 1 --> 5 songs which has ---> [2008} in front of every single album name.
I can't search for specific album due to the fact that the year are in front of the album. Is there any way I can select all the folders within {2008} and then remove the year in front of the album names?
You have no clue how thankful I would be if this can be done easily. This would save all the hassle from me going through every single album and removing the year.
Awesome... Thank you so much! Now only if I can some how align the year
The only thing complex about your example is that you have a [ character in your original filenames. Since [ has special meaning in regular expressions, you need to "escape" it with \ and use [ where you want to match a [ character (like I did in my post above). Beyond that it's basic regexp stuff.
Give it a try and we'll help you learn how to use regexps yourself.
