The sort option don't work with folder, only with files. Can you help me?
Thanks!
Thanks!
You probably have the option enabled to keep folders sorted alphabetically.
Where? How to disable?
Tools -> Folder Options -> Display -> Keep folders sorted automatically.
Also see the Folder Formats FAQ.
[quote="leo"]Tools -> Folder Options -> Display -> Keep folders sorted automatically.
Also see the Folder Formats FAQ.[/quote]
Thank you! Problem solved!
Yeah i also want to do the same but i want it for all the drives and folders but with Tools -> Folder Options -> Display it pics only the current drive or for particular folder i am already there..so how can i make this default option for all the folders?
Read the Folder Formats FAQ. That's the first thing it explains.
actually i read it but i couldn't get it...but i read hard then i got it finallly ...and at the end THx
