When I open the new folder on network with Directory opus, its action is not good, it will spend more time to read the folder;
But the same operation in Explorer, the speed is very fast.
Please link your account.
Zushi Zhang
Is this one?
I don't know what you are asking, sorry.
Link your account here: https://resource.dopus.com/link-opus
I haved linked my account sucessfully
My problem is opening the server folder in Opus is much slower than opening it in Explorer. It takes a while to load each time
Thank you.
If Preferences / Folders / Folder Behavior / Sort shortcuts to folders like folders is turned on, please try turning it off.
If that doesn't help, is the server on a LAN, or over the internet?
I have tried this, but it didn't help.
The server id on a LAN.
Actually all the operation on the server with Opus will take a few time more than the same on the Explorer
Have you checked everything under Crash, exit or high CPU when viewing certain directories ?
If nothing there applies, please send us some Process Monitor logs of the folder being read: Process Monitor instructions
Please check your private message, I have send the Logfile to you, thanks
Thank you.
Which folder should I look for being read in the log?
I need to know which operations to look at. Which folder was read when you made the log?
It looks like a lot of other activity was done, e.g. renaming some files, so I don't know which part of the log to focus on for the issue with reading a folder.
You can just check the renaming, this is also very slow.
Please just tell me which paths to look for, or I am not going to spend any more time on this.
M:\BIW_Engineering\25_SAIC\MBSC-2202\025_3D\99_Other Data\01-供应商交互\02_车身数据
Can you see this path?
