I am working on creating a theme, which will include (hopefully) modifying the colors used by the statusbar.
Here is what I have in
In Settings -> Preferences -> Display -> Colors and Fonts -> Other Colors -> Status bar
(the background color is the one I want to use for the entire statusbar and all it's elements)
In Settings -> Preferences -> Display -> Status Bar
Here is a screenshot of the current statusbar:
I realize I can uncheck "Glass background" and get the correct color, but not without the result including a visible border around every element in the bar and the bar itself (the color of the border being, well not what I would select if I were forced to have a border).
Trying to use "System colors" had no effect on the background color (with Glass selected) however it did turn the font color black, which is not desirable.
I have tried to tweak the various settings in
In Settings -> Preferences -> Display -> Colors and Fonts -> Other Colors -> Pane borders
but with no success. If I were to guess, given the presence of lister column headers and scroll bars, I would guess that this would be the place for an option for the status bar border. (This is usually where I sign up for the beta test program and see what the very latest build has to offer in this regard! )
As always - any advice/insight is greatly appreciated!
Regards,
-David
