TagMaster Script add-in (preview)
TagMaster brings tagging in Directory Opus to another level. It gives you an easy to use interface where you can manage them through a database, add them or remove them from files with a single click, plus edit descriptions and ratings. You can run it linked to your current file display selection or in a fuller standalone mode for batch work.
Features
  • Global tag database for searching and reusing tags across files.
  • Cloud-like interface for tags with quick visual browsing and single-click add/remove.
  • Support for categories and subcategories across your keywords.
  • Search field to find tags fast.
  • Bulk apply and "Add all" to tag many files at once.
  • Per-file description editor for short captions or notes.
  • Star rating editor integrated in the panel.
  • Two operation modes: Linked (follows Opus selection) and FULL (managed file queue).
  • Preview and properties panes so you can confirm content before applying metadata.
  • Apply / Reset workflow to stage changes before committing.
  • Optional wildcard FILTER preselection for easy file management selection.
  • "No-block" concept applied when reading metadata. So you can cancel the command at any time instantly.
  • AutoTag: automated analysis for images and PDFs to generate suggested tags and a short description (read About AutoTag section).
  • AutoSort uncategorized tags: automated sorting for uncategorized keywords (read About Categories section).
Requirements
  • Directory Opus 13.20.3 or newer.
How to Install
Download the file from releases and double click it. Or follow the instructions from here
Latest version : Download from here
Usage
Run the command by using TagMaster.
By default the dialog links to the current selection: pick files in Opus and the panel shows their tags, description input, preview, and rating values. There's also the FULL mode dialog, who has more additions and where you can work with any passed file and drop files in to add them to the batch.
In FULL mode, when folders are passed, they are read non-recursively by default (Use RECURSIVE to make it recursive). Otherwise they are ignored.
In AUTOTAG mode, you can set the files you want to handle automatically using AI models. More details in the Autotag argument section.
Tagging
There are 2 panels in the window: one that shows the tag database (which has a filter at the top) and another panel that lists the common tags for the selected files.
Click any tag in the database to add it to the selection.
To remove a tag from the selection, click the ⓧ on the tag you want to remove in the list panel.
To remove ALL tags from the selection, click the ⓧ in the list panel and confirm in the following dialog.
To remove a tag from the database, click its corresponding ⓧ and confirm in the following dialog.
You can add ALL tags listed in the tags panel using the "Add All" button. (Be careful where you use it.)
You can also add new tags that are not in the database. To do that, perform a search and the script will automatically detect if the tag is new, giving you the option to add it to the database and to the selection. You can add multiple tags if you separate them with ";".
Click the Options icon (cog) in the tag database panel to access options:
  • Add Tags from items to database: By default, the script adds every tag it finds to your database. Disabling this option makes the database read-only.
  • Import from Opus database: Opus has its own tag database. This option lets you import it for use.
  • Auto sort Uncategorized: Automatically sort uncategorized keywords with IA. (more in About Categories section).
Setting rating
You can also set the rating for the selection simply by clicking the rating you want.
Press the ⓧ button to clear the rating.
When multiple files are selected with different ratings, the text "multiple values" will be shown.
Setting description
You can set a description only when there is exactly 1 file in the selection.
Reset
Pressing this button will reset all values to their initial state (the state when the file was first read).
Apply
Press the button to apply any changes you made, if any. Note that in LINKED mode, saving is always automatic after changing the selection or closing the dialog.
In FULL mode, if you try to close the dialog with unsaved changes, you will be asked if you want to save them before exiting.
Filter
If the FILTER argument is used, files will be filtered using Opus wildcard syntax, so only files matching the given pattern are included.
In FULL mode, the filter is applied recursively to the contents of folders.
Preview and Properties
In FULL mode, you can see useful information about the selected files, and a preview. Use F6 to change to Preview and F7 to view the file properties.
Command arguments
Available arguments are:
Argument Type Value Description
FILES /M Sets the files to act on in FULL and AUTOTAG mode. If no files are specified, the ones selected in the active tab will be used.
AUTOTAG /O Open the command in AUTOTAG mode.
[model] Specify any model to start AUTOTAG. Can be a built-in model or a custom one
unattended Run AUTOTAG in unattended mode. This means there's no user intervention required.
nodesc When using AUTOTAG, the generated description will not be used.
notags When using AUTOTAG, the generated keywords will not be used.
nocats When using AUTOTAG, the generated categories will not be used.
FULL /O Open the command in FULL mode.
ai Open the command in FULL mode with AI capabilities.
FILTER /R Pass a pattern using Opus wildcard syntax.
NOADDTODB /S Makes the command's tag database read-only.
RECURSIVE /S When reading folders, lets you choose whether to do it recursively or not.
MANAGE /S Not yet implemented
Technical notes
  • This add-in introduces 2(+1) novel concepts for scripts:
    • Tertiary processing: All metadata reading is done separately from the main process (like in another command), with both processes communicating transparently to the user. This prevents the UI from freezing during heavy loads and allows stopping the command at any time (except while saving files). It also lets the UI show information as it becomes available, without having to finish processing the entire file stack, giving a smoother feel compared to other add-ins. Very useful when reading folders.
    • Link to multi listers: The command can link to the current selection across multiple listers and respond smoothly for a JScript command, thanks to the use of timers and other implementations that showcase the scripting API's power.
    • AutoTagging using AI: Explained in the "About AutoTag" section.
  • Files marked as "online only" are ignored in all cases.
  • The command uses an in-memory cache to speed things up and optimize resources. Once a file is read, it stays cached while the command runs. It can also detect file changes and will automatically update its data.
  • Folders are read non-recursively in FULL mode (unless yo also use the RECURSIVE argument, and the filter is applied if set.
  • In LINKED mode you can also use a filter, though it's not recommended because it can be confusing if you don't fully understand how it works.
  • The command is NOT meant for files where the path type is shell|mtp|ftp|plugin|zip.
  • Most strings in the configuration dialog depend on the current Opus language. Any strings not translated will appear in English for most users unless you run Opus in Spanish (Mexico).
About Categories
v0.9.3b brings support for categories for keywords. The switch to that mode is automatic.
To organize your database, (for now) you must edit the JSON file located at /dopusdata\User Data\TagMaster\database.json, using the following format:
  • Root object MUST contain a categories property (and may optionally contain uncategorized).
  • categories is a recursive structure (categoryNode):
  • If a categoryNode is an array, that array must contain strings (these are the keywords).
  • If a categoryNode is an object, its keys are subcategory names and each value must again be a categoryNode (so nesting can continue arbitrarily).
  • uncategorized is an optional top-level array of strings used for tags that didn't fit any category.
  • Keys (category names) are arbitrary non-empty strings, who shouldn't contain any of the following characters : $;\;/;:;_
Eg.
json
    "categories": {
        "cat1": [
      "tag1",
      "tag2"
        "cat2": {
            "cat2.1": {
                "cat2.1.1": [
          "tag3",
          "tag4",
          "tag5",
          "tag6",
          "tag7",
          "tag8",
          "tag9",
          "tag10",
          "tag11",
          "tag12",
          "tag13",
          "tag14",
          "tag15",
          "tag16",
          "tag17",
          "tag18"
                "cat2.1.2": [
          "tag7",
          "tag8"
            "cat2.2": [
        "tag5",
        "tag6"
    "uncategorized": ["tag x", "tag y"]
From now on, when the command "reads" new keywords, it will include them in the "Uncategorized" category.
If you add keywords manually to the database, they will be added depending on the category currently selected. If the category is "All" or a "folder", they will be added to "Uncategorized".
"All" shows the list of all registered keywords.
It's also possible, if you have an AI model available, to use it to auto-sort keywords without a category. To do that, in FULL mode press the cog icon on the database control and choose the "Auto sort uncategorized" option.
The model used will be the one currently configured as active in the selector next to the AI button.
This method prevents the AI from inserting random new keywords. Depending on the model used, it may not be able to categorize all of them, but no keywords will be deleted (those without categories remain in "Uncategorized").
When using this feature, a backup of the database is created first, so it's safe to revert if you don't agree with the changes.
About AutoTagging
This command can use AI models (the most popular ones) to "understand" images and PDFs and suggest descriptions and tags.
AUTOTAG mode can be accessed from FULL mode when using the ai option (on the selected file), or as a standalone dialog that supports multiple files, invoked with the AUTOTAG argument.
Originally this script was intended for my personal use, and it was tightly integrated with another add-in that, among other things, lets you manage models and their API keys. Since that other script isn't finished, this one lacks a UI for managing models and API keys.
As a workaround, this script includes several known models by default. To use them, you must have the corresponding API keys set in environment variables. This is common practice, so if you already have keys stored, you can use this feature (the variable names should be the standard ones, e.g. OPENAI_API_KEY). I'm not going to explain here how to obtain or store them in envvars, there's plenty of detailed info online.
You have some extra AI-related configuration options. Click the Options button to open them.
There you can choose whether to resize images and set the maximum width and height. This helps avoid unnecessary load from very large images.
You can also override settings like the response language; by default it uses Opus' current language. Enter a valid language name in English.
When the command starts it will detect if you have any keys installed and enable the corresponding models. In that case, when you select a single image or .pdf file, the AI button is enabled. Next to it you can choose from several enabled models.
Once the request is made, the next window shows the results if there's a response.
Results can be edited, discarded, or accepted.
Note 1 : This script does NOT upload any file to AI service servers automatically, nor does it misuse your credits. If you use it, you are fully responsible for the content you send, which is why the process is intentionally manual.
Note 2 : Images that are not .jpg, .jpeg or .png are automatically converted to .png and resize it before sending.
Note 3 : Images are sent "as is", without any metadata cleaning. So be careful with what you send.
The hardcoded models and the envvar they look for are:
Model ENV VAR
Mistral Models MISTRAL_API_KEY
Gemini Models GOOGLE_API_KEY
OpenAI Models OPENAI_API_KEY
Starting with v0.9.5, you can also bring your own custom models, like add-ons, and use them directly without modifying the script add-in. More details are available in the Custom Models section.
Autotag argument:
  • Works identically to AutoTag in FULL mode, but separately and with multiple files.
  • Optimizes processing time by pre-anticipating conversions and requests (requests are made ahead of time and not only for the file currently visible in the dialog). This maximizes throughput.
  • In regular mode, it allows editing the obtained data as usual, as well as changing the model at runtime and redoing a request.
  • Unattended mode automates processing with the chosen parameters and requires sufficient credits for the selected model (use common sense regarding the number of files to process).
  • Some options accessible from the FULL mode Options dialog apply here, such as image conversion and the language to use.
  • Files that encounter errors during processing are sent to a collection for identification. Useful especially in unattended mode.
  • Consider this mode alpha: it may have bugs—please report them with reproducible steps.
Custom Models:
Originally, this script allowed loading models through a UI. As of v0.9.5 this feature is partially restored.
To add a new model, create a JSON file in /dopusdata\User Data\custom models.
Each model file must be a valid JSON containing at least the following data (example for using Ollama - cloud is shown below).
Note that placeholders are used to inject data into the JSON. Placeholders are: __prompt__ (required), __base64_file__ (required), __schema__, __text_schema__, and __mime_type__.
The data value must be the same valid JSON structure the model expects for sending files encoded in base64. Consult the specific model's documentation to know this format. text_data contains information for sending/receiving text. Both are optional if the model doesn't support that input type—but at least one must exist.
response holds an array that "leads" to the response in the JSON object the model returns. Consult the model's documentation for this.
The model must also support structured outputs, which this command uses to obtain the response. The schemas for both cases are provided by the command and should not be part of the JSON; use the __schema__ and __text_schema__ placeholders instead.
modal_vision, modal_text, modal_audio, modal_video, modal_docs indicate the input modalities the model accepts. For example, a model that supports image recognition should have modal_vision (required for this command).
api_name should contain the name of the environment variable (DO NOT PLACE YOUR API KEY here). If the model does not require a key, use no_api_needed.
If the model uses a key, auth must exist and must be an array of 2 values that will be sent as a header with the API key value. Most will use something like:
['Authorization', 'Bearer ']; but other variations exist such as
['x-goog-api-key', ''] ; in that case leave the second value empty.
DO NOT USE the built-in model names, as they will be overridden.
For Ollama, the command assumes Ollama is running at request time (it will not try to verify or launch the program).
json
  "name": "gemma3:27b-cloud 2",
  "display_name": "Ollama Gemma3 27B cloud 2",
  "api_name": "OLLAMA_API_KEY",
  "endpoint": "https://ollama.com/v1/chat/completions",
  "auth": ["Authorization", "Bearer "],
  "model": "gemma3:27b-cloud",
  "data": {
    "messages": [{
      "role": "user",
      "content": [{
        "type": "text",
        "text": "__prompt__"
        "type": "image_url",
        "image_url": "data:__mime_type__;base64,__base64_file__"
    "response_format": {
      "type": "json_schema",
      "json_schema": {
        "name": "keywords_and_desc",
        "schema": "__schema__",
        "strict": true
  "response": ["choices", "0", "message", "content"],
  "modal_vision": true,
  "modal_text": false,
  "modal_docs": false,
  "modal_audio": false,
  "modal_video": false,
  "max_size": 10485760
About the Manage DB window
Lets you manage your database through an easy-to-use interface. Can be invoked as a standalone dialog via TagMaster MANAGE or from existing dialogs, by pressing the Option button in the database pane, and selecting Manage categories and keywords.
  • You can create new categories, folders, and nested categories.
  • You can delete entire categories.
  • You can rename categories.
  • You can add, edit, or delete keywords in any category.
  • You can import keywords from the Opus database.
  • You can auto-organize uncategorized keywords using the AI models you have available.
  • Create subfolders and subcategories inside folders (by right-clicking a folder).
  • It has a small stack that lets you copy keywords between categories when deleting them while holding Ctrl.
  • It includes an option so that when deleting keywords from a category, they are moved to the Uncategorized section instead of being deleted.
  • Hotkeys:
    • F3: Focus filter.
    • Escape: One time to clear the filter, another to close the dialog.
    • F2: Rename selected category.
    • Ctrl + N: Add new category.
    • Ctrl + Shift + N: Add new folder.
Whenever you try to save your database from this window, a backup copy of your database will be saved, which you can find in /dopusdata\User Data\TagMaster.
If you want to help
If you're interested, try the script and report edge cases or any suggestion you might have. Feedback will guide the next improvements.
Any suggestions or test results are appreciated. :wink:
Currently the dialog are full translated to English and Spanish (Mexico). If you want to help to translate the dialog into your current language, feel free to send me a message.
Credits / Acknowledgments
  • GPSoftware team for Directory Opus.
Disclaimer
This is an independent project that uses third-party AI services and APIs.
This project is not affiliated with, endorsed by, or sponsored by any of them.
All product and company names are trademarks or registered trademarks of their respective owners.
I knew nothing about API keys, but did understand Environment Variables.
I was able to get a Google Gemini API key and have it working within 30 minutes.
Here is my first attempt to use the AI feature .
Thankyou !
I forgot to explain it above, but in Script Config you can change the response language.
By default, the language will be the one Opus is using, but setting AI Options > language output to another language can force a different one. The language you want must be written in English and be a valid language name the AI understands. Eg., using Opus in English but changing the language to "Spanish":
Awesome. Many thanks. Happy New Year.
A useful feature would be to set the filename from a list of say 10 AI suggestions.
Also, do bigger images take longer to upload and analyze, I reccommend resizing larger images.
A few pointers:
red arrows - uneven spacing
green arrow - control border missing
there is enough space here to increase size of these 2 lists so that scrollbar is not needed.
delete button is clipped
clicking the add all button
Thanks. Try the v0.9.1b version.
Setting programmatic positions for controls is a bit tedious, so let me know if you find any other inconsistencies.
FWIW, the listview size issues may be related to your current font/size configuration. AFAIK there's no way to "autosize" a listview, so there's no scrollbar. Maybe just one listview but with gorups should be better.
May be a good idea. Everything could be done in a single request. But in that case, you would probably want to decide whether to ask for names too, right? That would mean more buttons/menus, and I'd like to keep the UI as simple as possible. Any idea how to implement it?
Yes, I actually talk about it in the Notes section. It might be worth implementing in future releases. Noted.
FWIW, I didn't implement it at first because the idea is that you might want to use a higher resolution for some reason. I actually thought about setting a limit of 1024px (height or width), but I'm not sure if that's the right choice. Any ideas?
I agree that if AI could try to specifically recognize an image and offer a list of possible names it could possibly result in better description suggestions.
But this only works if AI can really do that.
Yeah, that makes sense.
Here is an example where perhaps adding this feature could help if it really knows something.
This old US Fort was constructed after the War of 1812 near New Orleans .
Fort Pike was badly damaged by Hurricane Katrina and is still closed today.
The bridge in the background was also badly damaged and has been replaced.
Fort Pike
It looks like you're talking about something different.
What I understand is that you want to give the AI some context so it can give you a shorter description plus tags related to that context. But in that case, why would it even need to see the image? Since it wouldn't really be describing it anymore.
Or am I missunderstanding your point?
It does most of the time for this kind of tasks, I think.
Edit: You gave me some ideas, though. Google Lens can do something similar to what you're suggesting, if I'm understanding it right. But I don't think you can use the Cloud Vision API for free, I haven't checked that, tbh. Still, I'm going to try passing some context and see if Gemini can do something similar.
Yes, that's what I was thinking.
But I guess I'm kind of asking AI to replace thinking for me.
I see your point. I'm self defeating what AI is offering by asking this.
And yes, there is always Google Lens.
v0.9.2b:
  • Added an Options dialog to configure the new AI-related options.
  • Now you can change the response language at runtime by entering a valid language name (in English). Leave it empty to use Opus' current language.
  • Added an option to set the max timeout for AutoTagging requests. Default is 10s.
  • Added an option to resize/convert images to PNG when they exceed the configured max size or if the filetype isn't supported. Default is True, with max size set to 768px.
  • All image filetypes are now supported for AutoTagging.
  • When pressing the AI button, holding Shift lets you enter a brief description to pass as context, so you get a broader response.
  • Image encoding can be reused for faster responses.
You can do this now on runtime in the new Options Dialog.
Is implemented in v0.9.2b. You can access this by holding Shift while pushing the AI button. An example. Without any description :
vs setting a brief description before the request:
Also, from now on, all images supported for DOpus can be used for AutoTagging.
(Jon, maybe an argument for Image CONVERT that lets you choose NOT to copy metadata when converting would be useful?)
also another suggestion, in the ai dialog have a redo (do again) button.
also make the preview panel the same height as the filename panel. (increase height of description panel)
I don't think it'll implement the naming suggestion, tbh, it feels a bit out of place since the command is called TagMaster, not AITasks or anything like that. Maybe for another script?
Regarding making the preview resizable or larger, if you've ever created complicated dialogs with tabs and else, you'll have noticed that it's kind of impossible to have controls with shared dimensions within them. I remember I asked once, And I got zero responses. So I don't think it's possible. Perhaps if the space were divided into 3 columns instead of 2, but in that case, those using a lower resolution might have problems. I'll try to find a workaround one of these days.
Thanks for the feedback.
suggestion: move Apply button up with other buttons or move stars and Reset and AI buttons down to where Apply is. And either remove the unused space or change height of other elements.
Getting error 429 for Gemini 3.0 Pro Preview
and error 400 for OpenAi 4.1
Have not set up Mistral, do these two need subscription ?
Happy New Year ! and thank you so much sharing this wonderful script add-in. :star_struck:
"To remove a tag from the database, click its corresponding ⓧ and confirm in the following dialog."
I might be doing something wrong but I can't seem to remove tags from the tag database, as their corresponding ⓧ are not present next to the tags in the top panel (v0.9.2b)
:light_bulb: In suggestion I can see customizable 'tag categories' and sub categories for the database to be very useful along with custom 'multi tag presets' to speed up tagging workflows.
True. Thanks. Let me check why I initially didn't think it was a good idea to enable it in linked mode.
Regarding categories and subcategories, that was initially planned, but emulating everything you need for it added a lot of difficulty. A built-in TreeView control would be a huge help.
The presets thing sounds interesting. Do you have any idea/mockup about how to implement the save/load usage?
You can check the error codes for any particular model in their docs.
For Gemini, that means out of quota, I think.
Do you have a valid API key for OpenAI?
All the models included have a free tier, except for OpenAI afair (but it gives you the most accurate responses). Mistral is one of the most generous in that respect.
The OpenRouter models are free but since some time ago they rarely work for image recognition, at least for me. They are OK when processing just text, though.
Maybe something similar to the Find preset menu (if it's allowed to replicate/reuse?)
Then clicking in the tag database on all desigered tags to be combined in the field below (just as TagMaster is currently working) and then save as a preset.
Just an idea, I have really zero coding knowledge myself, so I have no idea if that is very doable or way too much work.
@errante
Thanks for what looks like it is going to be another useful Dopus add-in
