The right-click menu cannot be triggered with keyboard shortcuts in the Chinese/Japanes input method
In Directory Opus, I right-click on a file and can't use shortcuts in Chinese or Japanese input methods.
Which version of Opus are you seeing that in?
The latest version. Please check, thanks!
Is there any hope to fix this problem in future versions?This issue has a significant impact on usage...
That has been fixed in the current beta.
