The wildcard `'` can not work
In the quickfilter,inputing the filename "abc(2)" into it can not work even with wildcard ' added like "abc'(2')"
It works fine in the default Wildcards mode:
Maybe you have the filter bar set to Regular Expressions mode?
Thank you very much! You are right.
I noticed we still show the message about using ' as an escape character when the Filter Bar is in regex mode. We'll change that in the next update, since it's misleading.
great work
While you are at it: How about adding a little regex checkbox?
