How can I make the clipboard set copy the current folder name ?
Is there any way to make the clipboard set copy the artist of a mp3 file ?
Buttons forum: Copy the current path to the clipboard.
Could be done in a similar way to this, if you're comfortable writing a bit of VBScript. If not shout and I'll try and take a look when I've got longer.
For the #1 link, I was looking for something that would only copy the current folder not the path.
#2 If you have time to code something that would be greatly appreciated.
I should have been more specific for #1, sorry about that.
Use this in that case:
@nofilenamequoting
Clipboard SET {sourcepath$|noterm|nopath}
neat thanks!
