Using DOPUS for File Navigation
Friends
I am enjoying DOPUS and have been recommending it to friends (one of whom bought it).
Years ago, I used to use HANDY FOLDERS, a much limited version for DOPUS.
It had a feature that I still miss.
Can you include the Favorites drop down in the Navigation dialog boxes you get when you are opening or saving a file under Windows?
If this is not clear, say I am saving a WORD document. I get a popup window that allows me to navigate to a required folder on my drive. It would be great if we can use the FAVORITE icon on those navigation boxes.
Many thanks
You are not the first to think that this would be cool, unfortunately...
Thanks . . . hope you can keep it in mind.
You can check-out Quickaccespopup (QAP). Works with DOPUS and has an option to interfere in the "save as" dialog box and jump to favorites folder, active folder, etc...
Missing MagicASL, MCP, ReqChange... the replacements/enhancements on Amiga OS!
