I have just purchased Directory Opus 9 and I would like to use the vbscript rename feature to rename some JPEG files. The name of the JPEGs from my camera is in the format:
What I would like to be able to do is the following:
Sort the photos into shooting date/time sequence.
Prefix the JPEG name with the shooting date (date will be in the format YYYY MM DD).
Add a counter after the shooting date that starts at 0010 and increments by 0010.
The final name of the file should be (if the JPEG was created on the 15/05/2007):
Any help with this would be much appreciated.
Thank you for your help.
Neil.
