I use folder.jpg thumbnails in may folders with media (movies, mp3...)
When I view a folder list as tiles, the folder view this folder.jpg.
It would be really nice if the viewer pane would display the folder.jpg when i select a folder.
Is there a way to achive this. I thought to use an event that's fired when a folder is selected
but don't know where to start.
It looks like this command only opens the Viewpane which in my case is already open and If a folder is selected, the viewpane shows nothing.
I need a way to run a script when a folder is selected.
The script should look inside the folder if a folder.jpg files exists and if yes show it in the viewer pane.
I found in filetypes You can register events and there is a filetype "All folders".
But the button to create a new event for this type is greyed out.
Is this normal?
