Advanced Rename Dialog Default Settings
Opi….oh Opi!!!
Question
When I open my Advanced Rename dialog it opens with the rename Mode set to
Regular Expressions + Find and Replace
I want the default setting to be
Regular Expressions
How do I change this?
This is a specific instance of a more general enquiry about setting rename dialog defaults
I see a few over the years:
Changing Default Scripting Language used in Rename Dialog
Remembering rename settings
Make the default Rename be the "Last Rename
Answer
You specify the setting in the menu item/button call with the rename internal command switch
It is amazing how often I type out a question and in the process I answer for myself.
Something about clarifying the question in order to pose it jiggles my brain and….
hey presto!
Occasionally I have gotten far enough down the post to thing what the heck let me finish with an answer! Haha.
Upon posting I see a link which I did not find.
Answered already.
How to change the default settings for Advanced Rename
Oh well……
