I need to be able to automatically sort some folders in a different order. I've been advised to create a folder format. How do I do this?
You should have a closer look to the FAQ of this forum. You'll find leo's Folder Format Quick Guide and lots of other useful stuff for beginners there.
Folder Format Quick Guide: [url]Folder Formats: Quick Guide]
Have a look at the FAQs. In particular, the Folder Formats: Detailed Guide entry.
Regards, AB
Thanks, I did what I needed, took me a bit of time, though. In my opinion, it should be a bit more easier, may be the developers will consider simplifying this procedure in the future.
