Missing MOV Metadata in Metadata Pane + Using ExifTool as a Plugin?
I’m fairly new to Directory Opus, so this may simply be a beginner mistake. The Metadata Pane (F9) is supposed to show supported metadata fields, and the help file lists all available keywords here:
Keywords for SetAttr META [Directory Opus Manual])
However, when I select a *.MOV file, I only see "Two extended" and "Two standard" metadata properties (see screenshot 1).
If I view the same file with Microsoft’s ExifTool, I get a much larger set of properties (screenshot 2).
See plugin setting (Screenshot 3)
I have two questions:
  1. Is there a setting I may have overlooked that enables D-Opus to show the full set of metadata fields listed in the documentation—for MOV files in particular?
  2. I’ve read that ExifTool can be integrated as a plugin. Is there a step-by-step guide (“monkey-see, monkey-do”) for configuring this and associating ExifTool with .MOV files?*
Thanks in advance for any guidance!
There isn't much built-in support for editing .MOV metadata, I think due to our metadata library not knowing about the format.
You should be able to display at least some metadata in columns, although I don't have any tagged .MOV files to test with and Windows seems to only have read-only support for .MOV so I can't easily tag the files I have to try them. AFAIK it should work, though.
If none of the built-in columns show what you need, you may find a suitable column under Preferences / File Display Columns / Shell Properties which you can turn on in Opus. That lists File Explorer's columns and lets you use them within Opus.
If you want to use ExifTool to display information in columns:
There's also MediaInfo:
(Opus also uses MediaInfo for read-only metadata, but those let you add more columns than the ones that are built-in.)
I'm not sure what the best way to edit MOV metadata is, although ExifTool can probably be used to do that as well.
I posted a motion jpg mov video sample from my old Minilota Dimage here .
There really isn't much information of value there though.
I suggest that in Shell Properties you enable ‘Media Created’ date'.
Sorry I have not responded to your email.
