I'm trying to get DO to display the color labels that certain images have.
Those labels are in the XMP data. Both FastPictureViewer and XNView show the XMP color labels, but i just can't figure out how to show them in DO. If i add the "Label" column in the lister, it just stays empty.
I'm getting images from other people that are marked with certain color labels, and i want to be able to sort the images by color label in the lister.
You can check the files with PrintMeta to see if the tags are present. If they appear as a shell property, you can add them directly to Opus. However, if they only appear in ExifTool, you’ll need an add-in.
If you’d like, you can upload a zipped demo file, and I can check it for you.
Thank you, lxp. Unfortunately those specific tagged images are of sensitive nature. So i'm trying to install your PrinMeta add-in.
From your detailed description, i can't figure out where to install Mediainfo.CLI. Could you give me a pointer? Should it go into "%appdata%\GPSoftware\Directory Opus\Script AddIns\CLI"?
Yeah, those. Weird - when i ran ExifTool in the console, it outputted a "label: yellow".
But if i need v13 for the other add-in, i think i'll need to work out some other method of meta tagging for when i'm receiving images. For now - and maybe i'll upgrade sometime later this year.
Still, thanks a bunch for taking the time to help!
