I am trying to figure out how to save the column widths in a lister so that I don't have to resize everytime I open a lister.
Please advise.
Rob
Please advise.
Rob
Make sure the auto-size columns option is turned off:
The Folder Formats: Quick Guide should have all the other steps you need.
Where do I find this setting? I am using v10.
See step 1 of the guide I linked at the bottom of my previous post.
Thank you this worked.
Didn't work for me. The columns still change.
Oh, how long for a "Set current columns spacing as default". Just imagine; you could condense the whole "Folder Formats: Quick Guide" into ONE line of text.
Oh well.
If the auto size option is turned off the column widths won't change.
It is turned off. I did exactly as per the instructions, checked, double-checked and checked again.
I copied the preferences from my desktop machine (where columns stay still) and imported onto my laptop. No dice.
Thanks for your patience though. I know it can be irritating to hear me complain about this. Somehow I managed to get it to work on my desktop pc, though I seem to remember I had to repeat the procedure a few times, before it "took".
I am able to save my desired column widths OK, as per the above.
However, that setting does not affect the width of the tree pane. It keeps opening wider that I want it, resulting in my righthand column not displaying completely? How can I also set the default tree pane width?
The tree isn't a file display column, so the option wouldn't affect it.
Instead (or as well), use Settings > Set as Default Lister to save the layout of the default lister (assuming that is what you are loading later on; if you're using a lister layout, or a lister style, save over that instead as appropriate).
This is a very old thread, but I have the same issue. I use details view almost exclusively and just want to have my column widths stay where I set them. If I turn off autosize columns and hit apply, and then close DO and reopen it, the columns are right back to where I do not want them, and if I go back to the autosize setting, it is still checked, even though I unchecked it seconds ago. Any suggestions?
In case it matters this is in detail view with lister set to dual vertical.
Thanks
Thanks, those were useful. The issue was that I was not hitting "save" at the top of the dialog. I totally missed it, and just assumed if unchecked auto-size columns that from that moment it DO would just remember where I had them last set.
