Folder Formats: Quick Guide
This FAQ explains how to make Opus use the same format in all normal directories.
There are two closely related FAQs which you may wish to read afterwards:
This FAQ assumes you are using Directory Opus 12 or above. There are separate versions for Opus 9 and for Opus 10 & 11.
What is a folder format?
Folder Formats define things like the view mode (Details, List, Thumbnails, etc.), which columns are displayed (Name, Size, Type, etc.) and the sort order.
To define the format used for all directories:
  1. Open an Opus window, point it at C:\, and set it to use the view mode and columns that you want.
  2. Open the Folder Options dialog (located in the Folder drop-down menu):
    (Opus 13: The name is now Folder Format instead of Folder Options, for consistency with the rest of the UI.)
  3. From there, click Save:
  4. Select Save format for all folders (make this the default).
    Assuming you also want to blow away any existing formats which may override the default format in specific folders, layouts, etc., you should also select both checkboxes below that:
    • Clear any saved folder formats
    • Replace the folder format in layouts and saved folder tabs
    Click OK.
Other settings you may need to change:
You may also wish to check these settings to ensure the default folder format is always the one which gets used:
  1. Go to Settings -> Preferences / Folders / Folder Behaviour.
    Ensure Enable Folder Content Type detection is off.
    Turning this off prevents Opus from changing format automatically when entering folders with file types (e.g. lots of images or movies).
  2. Go to Preferences / Launching Opus / Default Lister.
    Ensure Ignore folder format of Default Lister is on.
    (Directory Opus Light: Skip this part as it does not apply.)
    Turning this on means you get the same format when opening a new window as you get when changing folders.
  3. Go to Preferences / Folders / Folder Formats.
    The format you just saved is the User Default item, right at the bottom of the list, in the Default Format section.
    Look at any ticked items in the Folder Type Formats section of the list. Double-click them to edit and confirm they are as you wish. You can also untick any you do not wish to use.
    If you have just saved the default format using the steps at the start of the guide, Opus will have updated some of the Folder Type Formats formats for you, based on your new defaults with slight alterations. For example, the format for Collections will add the Location column to the ones you specified, as you would usually want that in collections. If you don't want that for some reason, edit it now.
    (The Path Formats section of the list can also come into play, but should be empty now if you selected Clear any saved formats in the main part of the guide.)
    (The Content Type Formats section can come into play if you did not disable Content Type detection earlier in the guide.)
    Click OK in the Preferences window to save your changes.
  4. If the Format Lock is on when you open a window then it can complicate things. You probably want to turn the Format Lock off, and then re-save the Default Lister, Layout or Style you are using to open new windows.
    For normal behaviour, the lock icon on your status bar should be open, unlocked, like this:
    FAQ_O12_FolderFormats_Lock
    With a dual-display window, the left & right (or top & bottom) displays have their own format locks. Ensure both are unlocked.
    The Default Lister is the most common way to open a new window. You can update it via:
    Settings > Set As Default Lister.
    (Directory Opus Light: Instead of using the Settings menu, have just one Opus window open, then turn off the format lock, and then close the window. The next window you open will use the same state as the last one you closed.)
    The Format Lock is not on by default. If a window opens with the lock on then it must be because you turned it on at some point and then saved over the Default Lister, Layout or Style you are using to open the window. If you need help working out what to change, please ask.)
Try your changes in a new window:
To test what you've done, close any open Opus windows, then open a new window and see if it is how you want it.
Always use a new window to check your folder format changes.
Video tutorial:
The tutorial on Resizing File Display Columns covers some of the same ground as this FAQ, in video format. The tutorial also covers other related subjects in detail.
Head to 12m20s in the video for the parts about Saving Your Changes and Finding the Folder Format for the parts most related to this FAQ. Or watch the whole video to learn about the different types of column resizing.
Folder Formats: Detailed Guide
Folder Formats: Quick Guide [Opus 10 & 11]
MP3 columns display
GO command - Sort Order
How do get transparent current row selection
How to change highlighting of a certain button?
Lister Styles and Thumbnail View
Change default column header order?
Default to details view on new tabs
How to set folder-column size for all folders on all drives?
Need help with appearance of DO 11 since reinstalling
Folder format question
Prevent Display of Compatibility Shortcuts
Confused by the filter command "set VIEWFILTER/O"
New user having issues with Power Mode
Style tab selected, but not active
Column Widths for listers
Folder Options
Folder Options
Apply View choice to entire folder tree?
How do you display actual number of bytes in Size column?
Sort folder don't work
Folder Options / Filters don't get remembered
Lister Styles Not Updating For Newly Opened Windows
Default lister not saving as expected
Setup "Relative Size Bars"?
Save default lister details column sorting headers formats
Couple of newbie questions
Remember each folder's view settings?
Viewing Corel Office Files
Directory sort order
Can the deafult content type be set/locked?
Sort Order
Holding column sizes
How do I save a custom interface?
Sort Order Default
New User-Default Lister, Folder Tree, Dual Horizontal View
Changing default view
Do Not Show 'Desktop.ini' file
Folder layout in Opus - Defaults
How are Listers supposed to work?
Folder column width question
Default Lister
Listers changing to Thumbnails
Viewer pane display options
Wanted to hide folders.Searched forums still need help
Globally disable column width autosize
View menu
Folders remember view
Always Viewing All File Contents Using the Same Columns
Change multiple lister styles?
Prevent auto-calculation of folders size on specific drives
Customizing column filter & width preferences in folder pane?
Viewing Windows Documents and Settings sub-folders
Styles and details view
Viewing in details
Size columns in file types
Help with folder formats
Icons and Licence
Settings not Retained
Sort type specifc to folder
"Apply to all folders" equivalent?
Auto Sizing & Thumbnails is Driving Me Nuts
Folder Options-Display-AUTO
Not getting a very basic aspect of appearance and settings
Global sorting by name of all file types and Details view
How To Hide Files Extensions
Folder Options: Save For this folder (and all-subfolders)
Where's my Local Settings folder?
Lister column view not saved
Sort Help Needed
Sevaral Questions
Change view on new Tabs and Listers
Opus Startup Folder and Format HELP!
How to apply global settings for columns?
How to hide the folders and files?
MRU list & folder sort retention
Adding new header column to all tabs in Lister
How "Calculate folder sizes automatically" option works
Confused about content types and folder options
Folder Content Incorrect - Can I Set a Default for a Folder?
Hide System Files
Hide System Files
Question About Sorting
OSX Invisible files
Display type won't keep
How to not show hide file or folder?
Selecting files & folders via keyboard
Hidden files!
Styles/Layouts - Sorting folders by size
No "Drag" capability & "List View" default
Lost folder preferences?
Automatic style swap?
Toggling Filter Filters On and Off
Possible Bug: Lister Styles not being saved?
How to get lister to display files in list and not in detail
Problem with Network Drives and Folder Options
Change which columns are shown in certain folders
View Mode (Power) on FTP's
Default View to Power Mode for ALL Directories
Sort Sticking
Folder Format Question - Content Type Overridden
How to hide certain files globally & permanently?
How to...? Name/save column layouts
Personalize Directory lister
File and folder settings
Keep column options when duplicating tab or switching folder
Unable to save window configuration
Thumbnails view reseting
Setting default for column titles/folder tree
Options of files : Colums of file
No Audio Properties Anymore
File Extensions in Windows 10
Disable ZIP-support
How to prevent loss of my columns widths?
Need help with new window settings
[DO10] How to make "list view" as default?
Default settings
Where is lister can i set the files to show by latest date
Folder options - saving sort by date modified
How to hide "Properties"?
How do I see file extentions?
Disable TYPE
Moving columns permanently
Dopus does not remember folder layout
How to save and apply displayed column
Show full file/folder names in DO v10
How to Set Short Column Widths
Details Mode. Files Aren't sorting by Date, American Style
Hide Folders always hides all folders "*"
Saving folder changes in a 4K laptop running Windows 10
Remembering sort column
File sorting in folder
Not remembering individual folder format settings
Use Power Mode in all folders
Totally confused - make all folders use the same columns
Save column width
Can't Get "Thumbnail" and "Details" Mode to Stick!
Change Default Columns
Always start in Power Mode?
New user and am totally lost
Default sorting of folder
Custom sort?
Collections, Folder Formats and Styles
Lister columns won't stay where I put them
Anyone having issues with Folder Options save types?
How do I 'Sort by Type'?
Lister Details Mode
Behavior of ftp lister changed
Standard view
How can I limit the width of the 'name' column globally
Applying startup lister to new tab
Folder columns not saving
Indicate lister is in network location by changing background color?
Folder view won't stay on "list" universally
Maintaining consistency in layouts
Command to resize pictures with windows plugin?
Relative Size Detail?
How to change the sort sequence to decending in default list
How to customize and save a default layout
Can't retain Name, Size, Type, Modified Block
I still don't understand display of folder columns
Saving lister layout
Column width adjustment
Escaping Full Screen
9.5.4 64bit on Windows 7 won't sort folders
TortoiseSVN 1.7.6 and Dopus 10.0.4.3
Default view mode
How to make View/Details in a Folder the default
Folder Settings vs. Default Lister
Difference between Preference and Settings File?
Select files with keyboard
Default Folder View (details/thumbnails/power)
Columns changed when going to/back from flatview
Inability to save or deleted files
Quick Set/Reset Current Lister Format
Unviewable rar files : sorting by file extension
Can't save lister view
Default audio sorting by track?
Default Column Position in Lister
FTP File Lister Column Defaults
Default lister
Hidden Files
File Sort Order
View "Details" in Lister
Default view for remote/removable drives
File size display?
Hoow do I get rid of the "owner" firld in the lister?
Folder settings revert to defaults
Can't get out of default Details view
Changing the Folder Options doesn't work
Details View for ALL folders?
Columns in files-window (and more)
Calculate Folder Sizes Automatically
Previous...It's driving me insane!
Group by date (modified)
New user has a couple basic questions
Sort Order -> Date (modified) -> reverse order (v8.2.2.1)
Inconsistent Management of Folder Settings
Saving settings
Show more of filenames in thumbnails mode
Hide some files allready in hidden mode!
Dopus-8 preferences
I am still having trouble with the list's view
Lister sort order - impossible for me to set it as I like it
Customization/options for best/quickest performance
Error (32) on delete
More than 2600 video files in a folder
How to ALLWAYS have dir list set to details?
Special keys and Conflicts
Color Code Folder Icon?
Applying a filter to a lister?
Preferences
How to display folders with the format Details?
Remove Folders from File list?
Resize columns automatically?
DOpus pinned to taskbar not opening changed setup lister
File Display Size
Default sorting
How to make all files with the same extension invisible?
Can't save folder format
Sorting Folders
File Pane NOT Refreshing Properly
Can I just import settings from 11 to 12
Padlock icon
Folder format in network shares: strange behaviour
Audio and Video Codec data doesnt display in lister movie fo
Changed folder image, not sticking
HOW TO: Understand and Configure Background Images
Change the order of the folder column display
FAQ section now up-to-date and growing
Folder view settings not sticking
How to set a default sort by for a drive?
Can't drag to resize columns
How to globally exclude "file type" column in folder views
How to make saved sort work?
Folder Formats not behaving
File display columns not right in search mode
Remove "Type" Column
New Version Causes Column Width Problem
How do I set a different sorting setting for different folder views?
Libraries extended by default when opening dopus
Folder with music sorts itself by track
Bug report: the attributes field won't (really) go
How to change default view in lister
Making "sort by reverse date" permanent
Hide file extensions does not appear to be working
How do I create a folder format?
Can I limit max width of column but still auto resizing?
Disable "Folders on top" by sorting. Is it possible?
Extension column keeps coming back
Filter in Layout
Default view
Thumbnails
Column trouble
Auto-size columns problem
Filename truncation after editing in List View
Save system lister new default settings?
Folder Formats: Special Folders [Opus 9 and earlier]
Remembering folder settings
Date sort not switching between Asce and Desc
Opus 10 Settings
Bug in directory sort?
Squares Windows Explorer
New filename, visually truncated
Opus 10 Settings
Check box mode is gone?
Sorting of Columns depends on folder level, but it should no
Columns by default
Columns by default
How to disable thumbnail view
Retaining column widths between tab changes
Individual Folder Properties
How to apply extra columns to view to all tabs
Keep rational column sizes/orders
Configuring Opus 10 to replicate XP Windows Explorer
Support for 4NT descriptions
Attribute Description Column Permanent?
How to display total folder and file counts in directory structure
Power mode questions
Column disappearing
Flie size listing is mixed
Different colors in different listers
Installing on rebuilt PC, need
Folder format not saving
Two quick Q's please
Remembering folder sort order
Problem with folder format
Opus 10, 11 and "location" in Find Files results
Find newest file in folder / subfolder and copy it to dest
Sort Order on Windows 7
Listers: Adding a column to all
Settings changed when launched from another program
File display default
Setting a default lister
Folder options
Extension
Default Lister view
Saving folder column selection for all folders - not working?
Keeping column formats the same in split windows
Hide a column in the file list view
Default folder format problems
How to save default lister in "list view"
How to save custom TAB across all TABs
Setting folder format
2 Very basic questions from a rank beginner
Folder Format Changes And Inheritance
Help required, but help files don't match program
Manual sorting - auto save and auto enable
Adding Columns And Saving The Lister
It was fun trying
How do I set column widths to auto-size
Hiding folders based on name
How to Change the Format of a Non-Formatted Folder
Missing the not-so-obvious
Drive lists Z to A
Layout won't stick
Changing Folder Formats in saved lister layouts?
Selecting files
Preventing thumbnail mode default
Display Window Sorting
Get rid of Duration
Content / Folder Formats
New to DO - default lister question
Display Files First, Then Folders
Opening Opus v10
Can't get folder format to stick
Fixed lister fixed column widths not preserved with new lister
How to Remove the "Auto-Size" Column Default for All Folders
Can't set automatic display folder properly
Complete path in title bar and manual column width in lister
Changing default setting for the columns in the viewer
Long names cause other columns to move right
Hidden files
Filename ordering
Startup folders
List of FAQs organised by topic
Resizing of Name column doesn't remembers between sessions
Columns layout (sorry if not correct terminolgy)
Display files by date and by last modified how to?
Default order of folder columns
Details by default, and Thumbnails for folders with media
Preferences are not stiking
How can I make Power Mode the default view mode?
Right layout
Request for a few quick tips on organizing my lister
Can't Change Default Lister
I hate power mode, but it loves me
Save current folder format with over-ride?
Auto changing columns in display modes
Universal listing format for all folders
Permanently "Ungroup"! How?
Make favorites use the default lister setting
Capitals won't stay CAPITALS
How to set lister to open DO with the hard drives display using Tiles
How to create a lister style with always details view mood?
Show folders before files?
Setting the default lister does not remember display options
Limiting the length of the file name and moving the modified column next to file name
Setting global Folder Format
Unable to enable Dual Display & set new display to List View
Default Lister does not function
Opening new lister via external program doesn't use Default Lister
Option to turn on/off file extensions
Tool Bar V10
Default column order for Google Drive and its subfolders?
Cannot change background color in details view
Modify default file & folder display format
Have to disable auto size all columns in details and power modes
Not show hidden files by default
Have Opus9 remember column widths of lister?
Show only details
Hide system files upon launching opus
Show/Hide Filters
How to save column configruation-width and column selection
How to conceal Hidden(?) or dimmed out files on the Lister
Have buttons for *.pdf, *.doc, etc.?
FOLDER sorted by name and files by modified
Filter out desktop.ini
Newbie question: Some of my file names are truncated
Date/time problem
Can I set Folder Options -> Mixing for system folders
Can each folder keep its own settings?
Folder Options no longer stick
Win7 hidden folders not shown
Description Column-How to Keep it Stable
Conditional Script Based on DOpus Environment State
Password Protection
Folder Formats / Default Lister
'group by' will not stay away
I want the file extensions to be always visible
Is it possible to set twin panes to be identical in format?
More Advanced Flat-View filtering example
File Explore Properties
Dual Display with same fonts as Default Lister
Change folder display items for all file types
View - sort by & group by
Changing default view to sorting folders by name and files by date
Loosing music track information
SORTORDER toggle between mixed, normal (folders before files
Not sorting folders starting with numbers as expected
List directories and files by date, NOT putting all directories first?
Saving changes to FOLDER FORMATE
Lister columns don't retain my set width
Adding Fields
Set the width and order of the file display fields
Configure folder view and sorting for each Lister?
New tab to display custom sorting style
Group by file type group
Default Sort By Modified (Date & Time)
Music files
Making Dopus remember column widths for a particular folder
Labels and Status
Folder Formats Auto Size Problem
Columns resize by themselves on auto-refresh
Find duplicate files with different filenames
Eliminate Attributes column
How can I make the column width fixed for specific views in V13
Folder sort preference
Display Full Filenames
Trying to permanently add "Data Rate" to the sortbar, always eventually resets
Is there a way to display row number, like in excel?
Columns width and sorting as default
How to stop columns reverting to defaults?
Save and restore view settings in DefaultLister?
Is there a way to set manual sorting > enabled to ON by default?
Looking for Tutorial Links
Everytime I click on a drive it defaults to Thumbnail view
Struggling with having a folder always sort by date
Choose default columns for Details view
Saving default Setting doesn't work well
Consistent layout for Folder Tree, Folders and Viewer Pane
How To Get Column Widths To Stick?
Setting lister up so that all listers show size of folders
Folder layout memory
How to permanently add ‘Date Taken’ Column to Details
Setting files in alphabetical order
How to change the view of Dopus when it is first opened
Forcing lister to sort by column other than 'Name"
Lister Not Being Saved
How set folders to be "Group by date and time (modified)"?
How to create default folder column layout
Disable column auto size
'User Default' view for every tab/new tab/from favourites whatever
Display Group Filetype Icons and Expand/Collapse Groups easily
Manual sort auto-save
Set lister column defaults
How to save the positions of the Tree, Find and Viewer panes
Save column width
Right mouse button stopped working, requires Dir Opus restart
Sorting persistence
Columns won't show in desktop, just "name."
How to hide the file extension next to the name
How do I force all listers and folders to change to my preferred default format
How to universally and permanently hide the file type column
Manual Sorting off everywhere please
Add sort option to all folders without changing the pre-existing folder formats
Change and save column sizes
Removed columns keep re-appearing
How to set "Details + Thumbnails" as a default folder view mode?
Single clicking a file in a lister doesn't open the file until I right click then view and details
Why is dopus so complicated, eg. column widths
How to get Directory Opus to remember file/folder views when replacing explorer
How to set default lister column order - I can't seem to get it to "save" (Windows 10)
Turn off autosize for filename column
Lock size of file display columns
How do I save a Column order?
What's the easist way to get rid of the 'Attr' column everywhere?
Can't set default lister to open when openning dopus
Column width
Feature "Locking the Format" doesn't work how I expected
Reverse alphabetical order
Default atributes for a Folder and alphabetical order?
Column Heading Settings
How to make display header width fixed?
Just installed OPUS 13.10 build 9004 8/26 and s format categories like comments and tags not visible
Where do I find the Folder options?
Flat View messing Folder Options
Freeze colums to here does not work
Width of directory displays
Freeze column from here
How to consistently sort folders in alphanumeric order, but files in date order
How to hide file extension?
Grouping disable
Walk-thru for the amazing Folder Format system?
Two questions while using the software
How to make manual sorting universal in Directory Opus?
Sorting of folders with leading '0' does not work exactly as I expect
Permanently Setting Check Box Mode
Why is this folder different?
Disable file grouping completely
Sorting after type is broken
How to apply to all folders at once "group by none" in file display area
Extension column too narrow
Fix length of filename column
Saving heading in main window panes
Folder Options not sticking
Changing all lister layouts
Display thumbnails toggle by folder
Default view in listers
Change default view to 'Type'
Resize column headers
Getting a dul lister format to "stick" and apply to all future folders
Auto-size columns not working
Save column widths every time
Default all listings to sort by 'modified date', dirs then files
