I have been able to save lister layouts for a number of things. However, I cannot get the lister to save as default layout when I do the following things:
Change column width (I want filename to be a narrower column)
Reorder columns so that date is the 2nd column
I have made these changes, saved them, saved as default lister, but it will not save as the default layout.What am I doing wrong?
Most likely other settings override your settings. You can get a hint, if you hover the mouse cursor over the
lock symbol at the right bottom of your lister (it works only if the lock is open).
You can also have a look in the folder formats FAQ:
Agree with abr. You save folder formats independently of the default layout... That was a big hangup for me when I was getting set up.
On the "Setting Up your Opus Interface" page of my tut, you might want to have a quick glance at the Setting up the "real" Default Lister section---some of it may apply to your setup, some not.
