[SOLVED] folders icons - again & again :?
Hi everyone,
I've seen a few questions asked about changing the default folder
icons. Okay.. Now I use a program by Stardock called Icon Packager with which I am sure many of you are familiar. This program changes the icons on the entire system, from drives, to folders, to file types, and the start menu. I find it strange that OME of the icon modifications made by icon packager are picked up by Directory Opus, but not all. For example, the system folders as "My Computer", "Recycle Bin", "Control Panel" (including changed icons on the control panel), and file types set by icon packager are all correctly displayed in Opus, but the file folder icons and drive icons are not. They are displayed as the same jagged, yellow and ugly icons.
So, I upgraded since 8.2.2.0 to 8.2.2.3 version (the last) because since the 8.2.2.2 DOpus was supposed to support custom shell icons made by programs such as IconPacker, BeeIcons, etc. But it's still the same.
So my question is what about you guy? Do you manage to apply all the changes in Windows made by Icon Packager in DOpus too?
Thanks for your answers.
PS: sorry for my english, I'm french.
I use IconPhile to change my icons which does the same thing as Icon Packager. I to had trouble with the icons at first but now the folder icons are always the proper ones.
I think it could be a problem with cached icons, Dopus needs to be restarted or perhaps Windows XP needs to be restarted for it to fully take.
Anyways it seems to be working correctly now in version: 8222 U
fred: have a read of [Directory Opus 8.2.2.3)
You probably just need to delete the registry value.
From the when everything else fails department.
               A fix for the folder icons will not change problem.
My situation is \ was identical to Freds situation. Exactly !!
My folders are now changing using TuneUp 2000 but I am sure that
Icon Packager and other like programs will work also.
             Long story short I made two changes.
  1. I deleted the " NoIconTrickery " from the registry.
    ( I do not think
    this helped as I had changed it from 1 to 0 with
    no effect. )
  2. I changed one setting: ( From a lister or the system tray icon: )
    Settings > Prefrences > Folders > on the option:
           " Enable Folder Content  Type Detection for "
             I changed the option from " Local Drives Only"
                   To   " All Local and Network Drives "
             This option is sellected ( checked ) by default. I left
                 it sellected ( on )
    Thats all. Just from hours of trial and error and a little luck.
    I have tested enough to prove that it definantly fixes my problem.
    I was working with a new install so most of the other options
    were still set at their defaults. Some other setting ( Probably in
    the same area and in folders ) may need to be set to the default or
    whatever.
     The system had to be completely reset !!   Turned off with
      the notification area icon.   Than restarted.  Reboot was not
      necessary.
     Please post back if this works or not. I have spent a lot
     of time hunting this bug.
      Richard
This would make no difference at all. Simply remove the registry variable as described above and restart Opus.
OK Opus. Goo goo g'joob.
When you are right you are right.
     It was DELETING the registry
     Key which fixed the problem.
I thought I had tried that before but apparantly not.
In other cases changing the ' 1' to a ' 0 ' would turn off the
registry key. Now I know better.
So for all future readers, deleting the registry key as instructed
cured my problem.
Thanks to everyone for all your help
Richard
[quote="rerice"]OK Opus. Goo goo g'joob.
cured my problem.
Richard[/quote]
As you say man :smiley:
I had done the same thing as you, changing the NoIconTrickery registry value. But right now I've deleted it and the magie appeared. It was so simple and I was so stupid not to do it first since I've heard of it. :unamused: but now 8)
Thanks Fred ! ,
  You made my day.  It's nice to know that someone else
   fell for that old tricK.
    Have one on me,
    Richard
