Walk-thru for the amazing Folder Format system?
I am a huge fan of DO! I am on v13.12 and I know there is a super extensive system for setting folder formats and assigning them to specific folders and sub-folders but I am having some difficulty sorting it all out through the documentation. Is there a walk-thru or tutorial on this specific subject anyone can point me to?
Specifically, I want to set up my Documents folder format (details list, my specific columns and widths) and assign it to a set of Drives and folders (and sub-folders), then do the same for Images and have that permanently assigned. I know this is easily done but I am stumbling and would appreciate any support and guidance you can provide.
Thanks!!
Marc
Thank you Leo!!
Leo -- I noticed that the FAQ appears to be an older version of DO. For example it shows selecting Folder and then Folder Option but that is no longer there as a sub-menu. I am on Opus v 13.12
Thanks!
It's in the same place with almost the same name, just called Folder Format now, to make it consistent with other places in the UI.
Thanks!!
