Filter by Column is a script command for Directory Opus, who makes it easy to quickly filter the current file display, based on almost any column content.
It can be used either as a regular Directory Opus command, an interactive filter with UI or as a FAYT command.
Its main features are:
- Filtering by almost all built-in Directory Opus columns.
- Filtering by Script, Evaluator and Shell columns.
- Search Mode, that allows you to perform an advanced recursive search with the same parameters instead of filtering.
- Define custom names to refer to a specific column.
- Filtering/Searching by columns even if they are not used (visible) in the current file display.
- Support for the following flags: ignore diacritics, case-sensitive, whole words and regular expressions.
- Support for filtering items in expanded folder.
- Specialized syntax according to the column data type (date, number, size, duration and text).
- Filtering can be performed on any column, either referring explicitly to the column number position, the custom name given to an specific column, or implicitly by "Name" column, current sorting column, highlighted column or any user-defined column.
- Option to define the data type for Script, Evaluator and Shell columns.
- Quick flags configuration from the same command.
- Can be used as well as a command (a.k.a. Command Mode) or as a FAYT script (a.k.a. FAYT Mode).
- Interactive Filter with UI, with same filter syntax support. (a.k.a. Dialog Mode)
- Support for multi filtering based on more than one column, when used in Command Mode or FAYT Mode.
- Support for command input history.
FAYT Mode Example :
(simple filtering)
(filtering with support for nested results)
Dialog Mode Example :
How to Install
Download the file below. Then double click the file or run Prefs SCRIPTINSTALL
and select the downloaded file.
IMPORTANT: Needs at least Directory Opus v13.5.1
v1.6.1 : FilterbyColumn.opusscriptinstall
Script Configuration
This are script options that applies to all the existing modes. In the Script Management window (Settings / Scripts). Select Filter by Column and click in the gear icon.
They are divided into groups, depending which mode may apply:
collection name | General | Collection name for the search results. |
create subcollections | General | Create sub-collections instead of overwriting search results. |
custom_columns_categories | General |
Here you can define the type of data that a column returns. Used for Script, Evaluator and Shell columns. type can be string, date, duration, number or size. |
custom_columns_names | General | Define custom names to refer to a specific column, using the following syntax: "mycolname":"col name"; Where mycolname is the actual column keyword. (Press this command's quick key twice to show a list of current column's keywords. Don't use any operator (&&,||,<,<=,>=,>,= or !) for mycolname value. |
log level | General | Logging level to be displayed. OFF to show only errors. DEBUG to show all messages. STANDARD to show only the most relevant information. WARNING to show messages that needs your attention. |
flags_quickkey | FAYT Mode | This option allows you to set the same flags without going all the way through Preferences > Filtering and Sorting > Quick Keys, simply by typing in the FAYT bar the character configured in this option. By default is set to ?. |
default_implicit_column | FAYT/Command Mode | If a column is not explicitly specified, choose between filter by name, current sorted column, current highlighted or user_defined_implicit_column value. |
enable_wilcards | FAYT/Command Mode | Set to True to enable compatibility with Opus standard pattern matching and/or want to use Textual Filters exclusively for FAYT/Command Mode. |
user_defined_implicit_column | FAYT/Command Mode | In implicit mode, filter by this column, if it exists. If not, the Name column will be used. |
max_history_size | FAYT/Command Mode | Maximum number of entries to be remembered. |
preferred_filter_mode | FAYT/Command Mode | Choose the method to use when filtering/searching on a Script, Evaluator or Shell column. |
show nested results with Textual Filters | FAYT/Command Mode | Enable support for showing nested items in results when using Textual Filters. This makes the operation take longer to finish. |
add column | FAYT/Command Mode | Add the referenced column to the results tab after the search. |
custom columns obtention | Dialog Mode | Choose the method to get values for Script, Evaluator or Shell columns.
Textual Filters: Faster, no temporary files. |
list Evaluator columns | Dialog Mode | List in DIALOG all Evaluator Columns. |
list Script columns | Dialog Mode | List in DIALOG all Script Columns. |
list Shell columns | Dialog Mode | List in DIALOG all Shell Columns. |
Usage
Filter by Column can be used in three modes : FAYT Mode, Command Mode and Dialog Mode.
FAYT MODE allows you to use it from the FAYT bar, being able to filter/search in the current file display with the specialized syntax.
Filter submode is the default state, and acts similar to the regular Filter FAYT, but with many more options, makes it easy to quickly filter the current file display by any property, even if its column is not visible (if not referenced by its position).
Search submode lets you perform an advanced search, using the same search parameters than the filter, but recursively, including all subfolders. The results are open in a collection in a new tab in destination.
COMMAND MODE allows you to use as a regular DOpus command, from a button, menu, etc. It has the same syntax as the FAYT mode and the same sub-modes.
DIALOG MODE is the interactive version of the command. It has a simple UI, which allows real-time filtering, presenting the current values as selectable entries, for any available column.
Syntax
Columns can be referenced in two ways : implicitly or explicitly.
Explicitly: By using the following syntax:
C
numberoperatorquery
number refers to the position that the column occupies in the current file display, starting from 1. If the first column is the Index(#) column, it is omitted from calculation.
e.g.C2=tag1
mycolnameoperatorquery
mycolname refers to the custom name given by the user incustom_columns_names
in Script configuration.
e.g.mycustomcoldate=today
Implicitly:
If none of the above syntaxes are used, it means that the column to be filtered is implicitly referenced.
- The column used will be choosed based on the
value. - In this mode, the
operator is implied (when used as a equal/not equal comparison).
e.g. txt ; !Dop ; > 30 mb
Operators:
Valid operators are =
and >=
. When the column is of type 'string', the valid operators are =
and !=
. For all other types, all operators apply.
Query:
query has specialized syntax according to the column data type:
Date :
today
,tomorrow
,yesterday
(yday
),thisweek
(week
),lastweek
(lweek
),thismonth
(month
),lastmonth
(lmonth
),thisyear
(year
),lastyear
(lyear
)- Text in the format
yyyy
,MM
(to refer to a month of this year) orMM-yyyy
[day]d
Filter only by day value shown, regardless of the other values
e.g. C2=12d will match both 12-12-2023 and 12-03-2021 values[month]m
Filter only by month value shown, regardless of the other values
e.g. C2=11m will match both 12-11-2023 and 12-11-2021 values[x]ha|da|ma|ya
Filter for[x]
hours|days|months|years ago from current date.
e.g. C2>=11da will match all values 11 days old from current date.- Times can now be taken into account when comparing, if the input contains them.
HH:mm
orHH:mm:ss
Filter only using the time value- Date in format
dd-MM-yyyy HH:mm:ss
oryyyy-MM-dd HH:mm:ss
(also without the seconds) - Text in date format supported by Date Object
e.g. C2 > 2023/12/12 - The following syntax, when using with
or!=
operator, have support forranges
(using..
as separator between both limits):[day]-[day]d
[month]..[month]m
yyyy..yyyy
MM/yyyy..MM/yyyy
dd-MM-yyyy..dd-MM-yyyy
oryyyy-MM-dd..yyyy-MM-dd
dd-MM-yyyy..dd-MM-yyyy HH:mm:ss
oryyyy-MM-dd..yyyy-MM-dd HH:mm:ss
e.g. 10-12d; 2000..2023; 7/2021..11/2023; 8-1-2024 1:34..23-1-2024 2:19
Size :
- number
bytes
|kb
|mb
|gb
|tb
|pb
e.g. C3>4mb ; C2<=100 kb - In conjunction with
or!=
operators, you can use notation for ranges using..
or-
between both limits (inclusive)
e.g. C3=2mb..3.5mb
Number:
or!=
or-
e.g. C2=4-7
Duration :
HH:mm:ss
,mm:ss
or any integer referring to total seconds
e.g. C5=1:10:00 ; c5 > 20- In conjunction with
or!=
or-
e.g. C2=4-7 (meaning seconds) ; c2=1:10:00..2:20:00
Comparison with other value : (Not available in Dialog Mode)
You can compare a column's value with the value of another column, using the following syntax:
colnameoperator{othercolname}
colname can be the column keyword or a custom name (or be ignored in implicit mode).
{othercolname} is a column keyword (only built-in ones are supported). Supported columns are accesible as suggestions in FAYT Mode.
Searching by Filetype Group
Finally, as a bonus, when you filter by Name
column, you can refer to any of your file type groups registered, using [grp]:
query, where:
[grp]
use (kind of) fuzzy match for all your registered file type groups. e.g.img
will match Image file type group. Note that for matching, it will use the displayed (translated) name for that group.- query It's used to filter for all files whose name match with
query
and belong to the specified file type group.
e.g. img:abc
will match all files whose name contains abc and belong to filetype group Images.
doc:
will match all files who belong to file type group Documents.
FAYT Mode
Configuration
First open Preferences. Then navigate to Filtering and Sorting / Quick Keys (or use Prefs PAGE=quickkeys
) and change the assigned quick key. Change the hotkey to the one of your choice. By default it is set to $.
Script Flags
In that same section, you can change some options too. Open the Filter by Column menu and check/uncheck according to your needs.
Case sensitive | Self explained |
Regular Expressions | Self explained |
Ignore diacritics | Self explained |
Whole words | Self explained |
Ignore undefined values | Certain files may not have data in some columns. For example, a jpg file cannot have data in the "Duration" column. By enabling this option, when a filter operation is performed, the type of metadata a file may have and whether the info exists or not is taken into account for their inclusion in the results. |
Filter only what is visible | When filtering, only take into account the current visible items. Otherwise filtering include hidden items as well. |
Search Mode | Allows to perform a search instead of a filtering, using the same parameters. |
Filter by Column can be used in two submodes : Filter Mode and Search Mode.
To enable it, you can either check the flag Search Mode (this will make the default mode), or invoking by double typing your configured quick key for the command (e.g. $ $)
Note that this acts as a toggle, that is, one $ to invoke the default mode, and two $ $ to invoke the other, depending on the value of Search Mode flag.
You can check some examples in the Examples section.
Command Mode
Filter by Column can be used with the following arguments :
Arguments
Argument | Type | Values | Description |
CONFIG | /S | (no value) | Easy access to Script Configuration dialog. |
EDITCATEGORIES | /S | (no value) | Shows the Edit Categories dialog, in order to edit column's types stored in DIALOG mode. |
CASE | /S | (no value) | Enable case matching. |
REGEXP | /S | (no value) | Enable regular expressions. |
NODIACRITICS | /S | (no value) | Ignore diacritics. |
WHOLEWORDS | /S | (no value) | Only match whole words. |
USEWILD | /S | (no value) | Enable use for DOpus standard pattern matching. This will derrogate functions to Textual Filters exclusively. |
IGNOREEMPTY | /S | (no value) | Ignore undefined (empty) values when filtering/searching. |
FILTER | /O | (no value) | Enable Filter SubMode. Otherwise Search SubMode is active. |
visible | Filter using only the current visible items. | ||
MULTI | /S | (no value) | Enable multi column support. You can use && and || as logical operators and parenthesis when needed. Use double quotes to escape literal characters that otherwise has an special meaning for the command. |
DIALOG | /O | (no value) | Enable Dialog Mode. With no other value provided, it will start with the 'Name' column. |
filterall | Use all the available items at start. Otherwise it will use only the visible ones. | ||
column keyword column index custom column name |
Use any column keyword, column index or custom column name to start the dialog with that column. | ||
QUERY | /K/R |
Set the query to use for filter/search. Everything after this argument will be considered part of the value (no quotes needed). e.g. FilterbyColumn QUERY c1=dop |
Dialog Mode
This is the ultimate filtering tool! It allows interactive and real-time filtering and provides quick options to select items based on the value of the specified column.
Usage
You can add this buttons to your column header context menu, for easy access.
Filter by '%1'.dcf (477 Bytes)
The dialog reads all available values for the specified column and displays them in selectable options. Pressing the checkbox (or double-clicking the value in the list) will filter the items that have the specified values in the tab.
You can filter the values from the dialog list using the filter box
In addition, you can select the type of filtering by clicking in the Filter Options
icon : Using FAYT syntax or as text only.
Script columns must be registered first to be able to use the FAYT syntax. To do this, with the target column, select in the category combobox
the desired type (string, number, date, size, duration) and click on the save category
icon (the floppy icon).
You can switch to any other column (except Script, unless you have started with that column), using the name combobox
at the top. This combobox also acts as a search filter, using the column label.
When searching a column of type 'string' or filtering as text, you can apply certain options, such as regular expressions, case match, whole words, and use diacritics.
Of the 4 lower buttons, the first 3 allow you to make changes to the selected values.
- Use the first to select all entries (or use Alt+1).
- Use the second to invert the selection (or use Alt+2).
- Use the third to deselect all (or use Alt+3).
- The
Refresh list
button (F5) allows you to synchronize the values with those of the current tab, but only in case items have been added (or a folder has been expanded). If you want to reread all the values, you can refresh the tab and the dialog will synchronize automatically.
Press the Save to Collection
icon to save the visible items to a collection (following the rules for collections in the Script Configuration).
The Edit categories
icon, allows you to modify or delete the categories saved within the dialog.
The dialog allows you to use the Lister on a regular basis, and even switch to other tabs. Note the following cases:
- If you switch to another tab, or to another Lister, the dialog is disabled. It is re-enabled when you return to the target tab.
- If you close or change the path in the tab, the dialog is closed.
- If you refresh the tab, the dialog is automatically synchronized with the new data.
Some columns (like tags, label, artists or attributes) that can had multiple values, are handled differently by the command, allowing filtering by choosing any of them individually, as well as being able to decide whether only one or all of the selected options should be present or not when filtering (using the Use AND checkbox
By default, values for custom columns are retrieved via Rename Presets. You can change to Textual Filters, changing custom columns obtention
in Script Configuration.
Finally, the button lets you 'ignore' all undefined values when filtering, similar to Ignore undefined values
flag in FAYT Mode, but in runtime.
FAQ
This FAQ was mostly developed based on the use in FAYT Mode, but certain parts (such as the settings) affect the other modes.
For simplicity, let's assume that the assigned quick key for this command is $, and that the filter is not the default one.
If you've changed the assigned quick key to another one, replace any occurrence of $ in the directions above with your new assigned key.
If you set this filter as default, usually is not longer needed to type $, unless you want to use another characters who is currently in use as a quick key for another filter. For using the non default mode, $$ is always required.
How to get a column name
E.g. User Description column
- First, add the column to your current file display.
- Now type in the FAYT bar: $$ and press Return.
- The Script Log will open if not visible. In there you can see a list of all visible columns. Copy the value after "Name : " from the target column.
- You can easy recognize the target column by its header value.
How to register a custom name
- First you need to know the name for the column you want to use. (How to get a column name).
- Now go to the Script Management window (Settings / Scripts). Select Filter by Column and click in the Edit button.
- In the new open window, double click in
custom_column_names
. Then in that window add the following at the end, in a new line:"custom name":"column name"
custom name
is the name you want to use to refer that column from now on. Change to your like. Remember this value is case sensitive, so custom name is different than Custom Name.
column name
is the column's internal name you just copied.
Remember that the syntax must include the quotes and the colon in between.
e.g."desc":"userdesc"
- Click OK button in all opened windows to save your new values.
How to register a custom category
Custom categories are used for Script, Evaluator and Shell columns only, in order to let this command know what type of data a given column handles.
Usually, Evaluator columns don't need to be registered, as the command automatically reads that data from the column data, but you can register a category if you want to replace that value with another one.
Any unregistered column is considered by default as text (string).
To register a category :
custom_column_categories
. Then in that window add the following at the end, in a new line:"column name":"category"
"column name"
is the column's internal name you want to register.
"category"
valid values are string, number, date, duration or size.
e.g."scp:col_search_test/tam":"size"
- Click in OK in all opened windows to save your new values.
How to configure flags
Current available flags are described here.
You can configure this in Preferences / Filtering and Sorting / Quick Keys:
or by typing in the FAYT bar $+? and pressing Return.
- You can change ? by changing
flags_quickkey
value in Script Configuration.
How to change between Filter and Search modes
$ acts as a toggle for Filter Mode
and Search Mode
$ to use the default mode
$$ to use the non-default mode.
By default Filter Mode
is the default. Search Mode
will be the default mode if you enable Search Mode
flag.
Examples
Context : Filter Mode
is set as the default mode.
Example 1
Filter all items in the current file display whose User Description column value contain "Grumpy Cat". I want to create a custom name for that, so I can use mydesc=Grumpy Cat
Procedure
- In order to refer a column by its name. first we need to check if it's registered under
in Script Configuration. - If it's not there, we need to first know its internal name. (How to get a column name), which is
userdesc
. - If is not already registered, we do it using
"mydesc":"userdesc"
(How to register a custom name). - 'User description' is a built-in column, so no need to register a custom category.
- Since we want to find "Grumpy Cat", but no "grumpy cat", check in flags Case sensitive.
- Type $mydesc=Grumpy Cat
Example 2
Filter all items in the current file display whose 'User description' column value matches exactly "Grumpy Cat".
Procedure
- Perform the same steps as the previous case regarding the prior registration.
- Check in flags Case sensitive and Regular Expressions.
- Type $mydesc=^Grumpy Cat$
Example 3
Search for all items in the current source folder and its subfolders whose custom script column named My Date has a value of 3 months ago or later, from the current date.
I want to refer to this column as mydate
Procedure
scp:mycoldate/mycoldate
"mydate":"scp:mycoldate/mycoldate"
. (How to register a custom name). - My Date is a script column that I want to be recognized as date, so I need to register it (if it's not already) in custom categories using
"scp:mycoldate/mycoldate":"date"
. (How to register a custom category) - Type $$mydate>=3ma
Example 4
Search for all items in the current source folder and its subfolders whose custom script column named My Date has a value not included in the interval between Feb 2,2001 09:54 and Dic 3, 2004 19:55. I want to refer to this column as mydate
Procedure
- Type $$mydate!=2-2-2001 09:54..3-12-2004 19:55
Example 5
I want to use the value from the 'Tags' column whenever filtering/searching implicitly. For example, to filter to filter all the items in the current file display that contain 'cat' in its tags
Procedure
- We need to know the internal name used for Tags column. which is
keywords
(How to get a column name). - In Script Configuration, change
touser_defined_implicit_column
and setuser_defined_implicit_column
tokeywords
. - Type $cat
- You may want to check other flags, like Whole words to only match complete tags.
Notes
- The command implements two ways to get values in custom columns (in all modes) : via Textual Filters and through the abuse of Rename Presets.
allows to choose the method to use forFAYT/Command mode
.custom columns obtention
forDialog Mode
. Each method has its pros and cons.- Textual Filters :
- It is faster, no temporary files are created or used.
- Support for nested results (either from an expanded folder or grouped flatview) is granted when
is set to true.
- Rename Preset :
- It is a bit slower, temporary files are created/used.
- Support for nested results out of the box.
- Textual Filters :
- If you set
enable_wilcards
toTrue
, that will automatically mean to always use Textual Filters inFAYT/Command mode
. Search Mode
always use Textual Filters.- The command is not enabled on sites perceived as 'Shell' type (e.g. This PC) or on MTP or FTP or PLUGIN.
- Unsupported columns are as follows:
Unsupported columns
'group':
'md5sum':
'shasum':
'blake3sum':
'crc32sum':
'sha256sum':
'sha512sum':
'thumbnail':
'status':
'sizerel':
'disksizeauto':
'disksize':
'disksizekb':
'disksizerel':
'uncompressedsize':
'dircount':
'dircounttotal':
'filecount':
'filecounttotal':
Changelog
v1.6.1 (Apr 21, 2024) : ColSearch.opusscriptinstall (39.7 KB)
- Fixed some empty values not allowing to unhide items in DIALOG mode.
- Improvements when selecting items in DIALOG mode.
- Code updated/cleaned up.
- Better logging system.
v1.6.0 (Apr 13, 2024) : ColSearch.opusscriptinstall (39.5 KB)
GENERAL:
- Dialogs will now use the font style and size you've set up in Preferences / Colors and Fonts / Fonts > Dialogs.
- Now you can see matches for nested items within a library, whether it's in an expanded folder or in grouped flat view.
- Changed the command label because it was too long.
FAYT/COMMAND:
- Textual Filters now support showing matches for nested items. To enable this, set
to true.- Just a heads-up, this might slow down the operation significantly. (workaround is not good enough but it works )
- Multi mode is now accessible via FAYT mode by turning on the
Multi Mode
flag. - In Multi Mode, if only one column is used, it switches back to the regular procedure, which can be faster in some cases.
- Added a busy indicator during filtering, allowing you to cancel the operation if it's taking too long.
- New arguments in COMMAND mode :
CONFIG
andEDITCATEGORIES
DIALOG:
- Script columns can now be listed during initialization.
- This includes automatic recognition of the data type, providing general benefits. For example, you won't need to register the column type if the dialog has been initialized at least once, unless you want to change the registered type.
- Added new entries in Script Configurations:
list Script Columns
,list Evaluator Columns
, andlist Shell Columns
, to toggle the listing of these columns during dialog initialization. (Useful if you have a large number of columns of a certain type, as listing them all could slightly delay the display of the dialog.) - Changes made to the 'Refresh' button in the dialog. It now always displays all items in the tab and syncs them with the dialog (previously, it was a bit confusing regarding which items to show).
- Checked values are now remembered under certain circumstances (e.g., when changing/editing a category).
- Columns with the same header are now suffixed with their keyword, preventing overlap and allowing all supported columns to be listed.
- All item labels, even non-explicit ones, are now listed.
- Fixed filtering issues with nested items.
- The dialog now avoids continuous calls for the same tab.
- Fixed some issues with edited categories been replaced when listing custom columns.
Full changelog
v1.5.0 (Apr 04, 2024) :
GENERAL :
- Introduced new Dialog Mode.
- New option in Configuration :
enable_wilcards
: Allows to use Opus Standard Pattern Matching (only in text type values). - Wildcard escape flag and
use_filter_builtin
were merged to avoid contradictions. - Now you can check if a column has data or not, regardless of its type. For that simply use colname
or colname!=""
. - You can now compare one column with another (not available in Dialog mode). To do that use colnameoperator{othercolname}
- Improved logic when you want to ignore unavailable (undefined) values. Should now work in all modes.
- Improved filtering of nested items (either by expanded folders or grouped flat view) in all modes (except where Textual Filters are used, there is no possibility in there). Now the command is able to show matches in these cases, showing also the ancestor folders.
- Improved conversion and comparison of columns set as number, in all modes. Decimals are now correctly taken into account.
- Some changes in the code to support the new features.
- Other minor fixes.
FAYT :
- Renamed flag
Ignore non qualified items
toIgnore undefined values
. - New value for
:current highlighted
, which allows implicit reference to the first selected column. To do this, the whole column must be selected beforehand, using right click + Ctrl. - New Flag :
, allows to apply the filter only on the currently visible items. useful if you want to apply 2 filters in a row (one on the results of the other).
- Renamed flag
COMMAND :
- Removed
ESCWILD
argument. - New argument
USEWILD
, to enable the use of wilcards in command mode. FILTER
has a new value :visible
, to mimicsFilter only what is visible
flag but for command mode.- New argument :
IGNOREEMPTY
, similar to theIgnore undefined values
flag. Can be combined with other arguments. - New argument :
DIALOG
, shows a dialog that makes the filtering process easier (The ultimate Excel-like filter function!). - New argument :
MULTI
, allows you to perform a multi filtering/search, referencing one or more columns, using logical operators && or ||.- In this mode, Evaluator and textual filters are used exclusively. (so no nested results are available)
- You must use parenthesis where applicable. To search for an operator or literal parenthesis, enclose the values in double quotes.
- E.g.
FilterbyColumn MULTI QUERY ext==exe && created>lastyear
- Removed
v1.4.2 (Mar 13, 2024) :
- Fixed printing columns information being broken in v1.4.1.
v1.4.1 (Mar 10, 2024) :
In all cases where Evaluator is used:
- Fixed incomplete results if in some cases you searched only by date without time.
- DOpus standard pattern matching can now be used properly (if regular expressions are not enabled).
- Also, now there is a new flag, to escape wildcard characters when you don't want to use it (if not enabled and regular expressions is disabled, it escapes characters for regular expressions).
FAYT mode:
- Improved detection when displaying suggestions (hopefully this is fixed for good).
Command mode:
- Added new argument :
ESCWILD
, to escape characters that can be interpreted as wildcards (applicable for cases where Evaluator is used).
v1.4.0 (Mar 06, 2024) :
- Now you can use
FilterbyColumn
as a command too. Valid args areFILTER
,REGEXP
,NODIACRITICS
,WHOLEWORDS
,CASE
, andQUERY
. - Now you can use column's keyword to refer a specific column, without previous name registration.
v1.3.3 (Mar 03, 2024) :
- Updated to work with the changes introduced in 13.3.2 (mostly affects when the script is the default filter).
- Added a new log level,
Standard
v1.3.2 (Feb 24, 2024) :
- Now, the column doesn't need to be visible when filtering/searching and not using a position-based column reference(e.g. C1, etc.)(there's no longer
Filter even if no visible
flag).
v1.3.1 (Feb 22, 2024) :
- Introducing '
Search Mode
' flag, to perform a recursive search in the current source folder, using the same filter and parameters. - Enabled filtering by filetype group when using
Search Mode
. - $ $ (or your configured quick key) works as a toggle between filtering and searching.
- Search Mode has several options for configuration (collection name, use subcollections, add column).
- Added range search for dates with the format:
- dd-MM-yyyy or yyyy-MM-dd
- dd-MM-yyyy HH:mm or yyyy-MM-dd HH:mm
- dd-MM-yyyy HH:mm:ss or yyyy-MM-dd HH:mm:ss
- Improved logic when searching by date ranges.
- Improved parsing of custom categories and custom names.
- Improved dialog for configuring flags. Now keyboard accelerators can be used. (also no more minimized listers).
- Improved suggestions when typing. Now all the custom names are included as suggestions, accesible for both Filter and Search Mode.
- Now custom names are case sensitive.
- Evaluator columns doesn't need to declare their type (date, number, etc), since is readed from the very column file. You can still declare it though, if you want to override it (eg. declare as duration type a text Evaluator column).
v1.2.1 :
- Now is possible to define custom names to refer an specific column when in explicit mode, using
in Script configuration. - Added a new flag: Use column even if it's not visible; allows to filter based on a column previously declared in
or inuser_defined_implicit_column
, even if it is not visible in the current file display. - Added
labels_access
in Script configuration, which allows to choose if the filtering by labels should include all or only those visible in the Label Column. (Please note thatuse_filters_for_builtin
set to true, override this option). - Minor corrections.
v1.1.0 :
- Textual Filters mode renewed, now it has no technical limitations and can be used to filter any relevant column.
- Rename Presets mode is kept for the time being, for legacy and comparative reasons, it can be changed by using the
option in Settings. - This brings a substantial time improvement when filtering Script, Evaluator and Shell columns.
- Option to filter built-in columns in Textual Filters Mode.
However, please note still has some very small limitations:- Can't get results inside expanded folders.
- Ignore non qualified items flag is not applicable.
To enable it, set theuse_filters_for_builtin
option in Settings to true.
v1.0.6 (2024-01-23)
- Added support for 'Permissions' and 'Availability' columns.
- Minor changes in script configuration dialog.
- Fixed filter by group not working in some scenarios.
v1.0.5 (2024-01-10)
- Added support for 'accessedtime', 'createdtime', 'modifiedtime', 'encodedby', 'mp3drm', 'aspectratiogroup', 'picphyssize', 'initialkey' and 'target' columns.
- Added
in Script Configuration, to init implicit mode on a specific column.
v1.0.4 (2024-01-08)
- Added filter by filetype group option when referring to "Name" column.
- Added 'desc' column support.
- Fixed 'userdesc' column not working properly.
v1.0.3 (2023-12-27)
[day]d
;[month]m
;yyyy
;MM/yyyy
and duration column types now support ranges (when used with = or !=).- Filters completely redesigned, now supports most cases and hopefully should return the same results as using Rename Presets.
- Fixed a possible error if trying to use an incomplete|incorrect regular expression.
- Added support for Zip type folders (when opening a zip file as a folder).
- Various bugs fixed.
v1.0.2 (2023-12-26)
- Added basic support for command input history (appears as a list of suggestions when typing in the FAYT field).
- Corrected diacritics filtering not working in some scenarios.
- New modes when filtering by date:
[day]d
Filter only by day value shown, regardless of the other values (only built-in and via Rename).[month]m
Filter only by month value shown, regardless of the other values (only built-in and via Rename).[x]ha|da|ma|ya
Filter for[x]
hours|days|months|years ago from now.- Times can now be taken into account when comparing, if the input contains them.
HH:mm
orHH:mm:ss
Filter only using the time value (only built-in and via Rename).
- Added support for "TB" and "PB" for sizes.
- Added support for ranges in columns of type 'number' and 'size'.
or!=
operators, you can now use notation for ranges using...
or-
between both limits (inclusive).
e.g. 2mb..3.5mb, 4-7
v1.0.1 (2023-12-21)
- Fixed an issue when filtering for values in Label Column.
v1.0.0 (2023-12-19) : Initial release
