Started using Directory Opus today, really love it, thanks!
However, there is a problem that I can't solve and that completely breaks my workflow.
The status icons for cloud files (Synology Drive) do not appear. I've added the folder paths to "cloud_sync_paths" in advanced options, but it didn't change anything. The column "availability" is working as expected.
If you pick a random file in one of those folders, and assign a status icon via the Properties drop-down menu (e.g. Checked), does it show the icon in that column?
I am having the same problem as @critical_lab. The Availability column populates correctly but the Status column does not. Explorer shows both. I have my Synology Drive folder defined in cloud_sync_paths and Show cloud storage status icons is checked. If I assign an icon manually to a random file it appears correctly.
I have just checked on my desktop which is accessing the same Synology Drive, and it does show the status icons. Both systems are running Opus 12.20.4 and W10 Pro 1909 build 18363.836. I can't think of anything obviously different between the two. I will check with a vanilla Opus configuration on the laptop to see if that makes any difference.
Just checked and it doesn't make any difference. Explorer shows status, Opus doesn't and yes, I remembered to add the Synology Drive path to cloud_sync_paths.
Apart from checking that the path is right and that you definitely have Show cloud storage status icons turned on I can't think really think of anything else to suggest?
Yes, Windows 10. Same version on both PCs which are both on the same home LAN. If I group by Status on the desktop it splits into the correct categories. On the laptop everything is grouped under Unspecified.
The desktop PC has a lot more accumulated "stuff" on it in the way of applications. The laptop is relatively new and I can't see anything suspicious among the shortish list of installed apps.
It would be nice to get to the bottom of this but it's really only a cosmetic thing. To be honest, until recently I had never applied the Status column to any cloud folders on the laptop, which is the machine I use most frequently. I certainly won't be losing any sleep if it remains a mystery.
The latest beta will output a bit of debugging information to DebugView when changing folders (basically it will show what folder it's changing to and the candidate cloud paths it compares it against). Have a look and see if it shows anything.
I ran on both systems. Neither system sees C:\SynologyDrive as a cloud drive but as reported earlier, the desktop shows Status icons whereas the laptop doesn't. Both systems do show (i.e. populate) the Availability column. Relevant?
Ok, thanks. Your laptop's log showed up a problem in Opus where the user-configured cloud paths will be ignored if neither OneDrive or Dropbox are also installed. We'll fix that in the next update.
Does your laptop actually have OneDrive on it? If it does then we're obviously misidentifying it for some reason.
On your desktop, it shows that C:\SynologyDrive does actually get recognised as a cloud path, and you say the Status icons work there, so I'd say that's all working ok.
00000021 0.52715939 [11304] [8680] dopus: CLOUD: Is "C:\SynologyDrive" a cloud path?
00000022 0.52717620 [11304] [8680] dopus: CLOUD: Test "C:\Users\admin\OneDrive"
00000023 0.52722609 [11304] [8680] dopus: CLOUD: No match
00000024 0.52723670 [11304] [8680] dopus: CLOUD: Test "C:\SynologyDrive"
00000025 0.52726001 [11304] [8680] dopus: CLOUD: Matched "C:\SynologyDrive"!
Apologies, I missed the "Matched" on the desktop log that was staring me in the face.
Yes, OneDrive is installed and operating normally on the laptop. The only difference in the settings is that Files-On-Demand is ON on the desktop and OFF on the laptop. Same build 20.052.0311.0011 (April 30, 2020) on both.
Ah, that explains it - with Files-on-Demand turned off, OneDrive just acts like a dumb sync tool and everything is always synced. Explorer shouldn't be showing Status icons in that situation either.
Thanks for all your help. This turns out to be related to my earlier question/report about video thumbnails. If Files-on-Demand is turned off I can see video thumbnails otherwise all I see is a generic video icon so it appears to be a case of one or the other. For now, I have switched Files-on-Demand back on and will live with the inconvenience of not being able so see what a cloud based video clip actually is.
