HOW TO: Enable/fix playback of various media formats in Opus
Plugin Config
Go to Settings / Preferences / Viewer / Plugins and configure the Video & Audio (Opus 13) or Movie (Opus 12) plugin.
Make sure it includes the extension you are trying to play in its list.
Codecs
If videos aren't playing, a codec is probably needed. Any you're likely to need are listed below.
All are free, except where noted.
There are two main codec types:
1. Codecs provided by Microsoft
Directory Opus 13 (or above) is required to use these.
These are delivered via the Microsoft Store, and also enable playback in other software that uses the newer Windows video APIs (e.g. the Windows 10 & 11 Films & TV app).
Installing all of them is easiest, choosing the most appropriate of the two HEVC options. But, if you want to be selective, the Movies > Video Codec and Audio Codec columns may tell you what a particular file needs.
The Opus Video & Audio plugin will use these codecs when MediaEngine and MediaSession are enabled under Playback methods in the plugin's config.
2026 update: A bug was introduced in Windows, Microsoft's codecs or possibly NVidia's display drivers which makes some of these codecs malfunction and even crash the entire machine for some people. Subsequent updates seem to have mostly fixed this, although it may still happen with certain videos. If you experience that problem, please disable MediaEngine and MediaSession in the plugin, and install DirectShow codecs as per the next section.
2. DirectShow Codecs
Alternatively, DirectShow codecs can be used in all versions of Opus:
  • LAV Filters (Handles virtually anything.)
  • There are many other DirectShow codecs out there, if your video needs something really esoteric.
  • 64-bit codecs are required. (32-bit codecs will not work with Opus's normal video player.)
The Opus Video & Audio plugin will use these codecs when DirectShow is enabled under Playback methods in the plugin's config.
Alternative movie playback plugins
Directory Opus 13 has a new video player, which we recommend sticking with if you're on that version (or later).
If you're on Directory Opus 12 (or earlier), and the DirectShow codec suggested above hasn't fixed things, it may be easier to switch from the default Movie plugin to an alternative.
For something to work in the viewer pane (rather than as a separate application/window), it must provide a Preview Handler, an ActiveX control, or an Opus-specific plugin.
Disabling the Movie plugin may be enough to get playback to happen via something else. This is done via Settings / Preferences / Viewer / Plugins. (Note that this will also disable some of the metadata columns which the Movie plugin provides. The Opus 13 movie plugin allows you to separately configure playback and metadata, but the Opus 12 one doesn't.)
If you don't get the results you want after disabling the Movie plugin, configure the ActiveX + Preview + Office + Web plugin to tell it to use something else for the appropriate file extension. The ActiveX + Preview + Office + Web plugin acts as a bridge between Opus and other types of components which can display files.
Video in viewer pane
MP4 Playback with Movie Plugin Fails
VideoLAN and DO
Movie plugin and FLV
DOPUS suddenly quit previewing movie files in viewer pane
Issue with .AVI files only on Opus; Explorer has no issue
Movie thumbnails/icons & preview pane not working
Video preview doesn't work
Media Preview plugin - Error
Play MP3 under Dopus
No Video in viewer
Windows x64 Viewer Pane Not Working
MP4 files not displaying in viewer pane
Failed to load ffmpeg.dll!
Volume in Viewer Pane: Always 100%
Built in viewer video looping
How do I adjust viewer pane to a different video player for Opus 12
Viewer Pane is slow loading media
Can't view MP4 in viewer
Show video thumbnails
Opus does not show previews
Internal player does not play anymore
Audio and mpg won't play in Viewer
Many videos won't play
Problems with video preview
Assign file ext to open with Opus instead of media player
Thumbnails for .mov and .mp4 crashing after Windows updates
Help with viewing flv and mkv file formats
Several multimedia preview concerns
Opus freezes with filmstrip
Videos does not show at all
DOpus v10.0.2 crashes and other issues
FLV playback x64
MP3 's don't play in view pane
Video not working
SWF Helper
MP3 album art in Lister Viewer Pane?
Autoplay of Video and Audio not working anymore
How can I make standalone image viewer include video files while cycling?
Tab [Filmstrip] MP4 no playback
Is there WebM support?
List of FAQs organised by topic
Content Type "Movies" no longer displays information specific to movies
Selecting .MP4 files with the preview panel open makes DOpus crash
Help needed to configure Movie viewer plugin to play videos
Play Audio command doesn't work in DOpus 10 & 11
All FLVs working in viewer pane
How to view mts files
Movie Specific Column Enabling
Mp4 thumbnails
Previewing videos failed in v12.30
The trouble of viewer panes
Thumbnails not displaying by CODEC?
2 issues to be resolved please
QuickTime (*.mov) Never Show Thumbnails
Movie plug-in often causes the do to be stuck or stays loading
The Viewer pane cannot play 10-bit video files
Mise à jour vers Directoy Opus 13 et probleme avec la lecture audio et video
Preview de arquivos mov (png)
Directory Opus 12.11 x64 crashing when a mpg file is clicked
Viewer Pane plays audio from a video but not the video
Video files cannot be previewed in the viewer pane
The 'Movies' plugin does not playback videos
Preview window does not show contents
Viewers keep failing
Cant Preview MP4 files (v11.19)
Since Last Update I've Lost the Ability to View MP4 / MKV Files In Viewer Pane
JPEG XL support with new Microsoft WIC codec
Opus & Explorer no longer show video duration metadata
Opus12 freezes on .mkv video files
Among MOV files, Apple Log - HDR files taken with iPhone 15 pro are not previewed
How to set default application for viewer pane video preview?
More Plugins: Interactive list of Opus Plugins & Media Capabilities
.ts files in the DO viewer
MP3 Tag Editing plugin (Obsolete: Use the Metadata panel now)
No thumbnails for .mp4
Videos in 13.5.4 no longer show a picture preview
Quicktime movies
Viewer pane won't run mp4 videos
Is there a way to select Particular folders/drives ONLY to be thumbnail cached and not everything?
Video preview chokes computer
Viewer Pane keeps file handle open
Missing Metadata for .ts files
Video/Image Preview Failure Despite Windows Media Player as Default
Video & audio plugin: separate video config from audio
How to display length for mkv movies in Duration column
Video player
Preview freezes DO
ActiveX Preview Player Controls on 4K Screen
Drag and Drop Zip problem with DO version 9.1.1.6 and up
Thumbnails containing images causes opus crash
Mpg (and mkv and ogm for that matter) Attribute Support
Playing .mov and .dat videos
Some FLV not playing
Internal viewer skips video files
Internal sound player for wav does not work
.FLV movie viewer not working for me
Using Directory Opus to play .wav files ...?
View squeezes picture into 1/2 of pane-below is black
Viewer shows hex for all video
Video codec, bitrate columns don't show anything except WMV
Play HEVC In Viewer Pane
FLC viewer?
Opus 9: folder tree won't receive color
File Type Groups Movies Inconsistent
Will DO11 support MP4 video metadata?
DO11: No video metadata
Resizing Tiles like Windows Explorer
How to disable the automatic preview?
Crash generating movie plugins
Freeze when preview some of the movie file
Playing an mp3 in the preview window
Playing Movie, but no sound
Problem with videos on the viewer pane
SWF Helper
Neither wav, avi, wmv show up in viewer
M4A Files will no longer play in dopus 10
Guide above has been re-written and updated:
  • Added information for Opus 13's new video player, including links to Microsoft's codecs.
  • Changed recommended DirectShow codec to LAV Filters, as it seems the best maintained these days. Should work with all versions of Opus, new and old.
  • Removed a lot of old information that's no longer relevant on current versions of Windows.
